Go Back   Automotive Forums .com Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 06-05-2005, 12:53 AM   #1
Lanzy61
Unhappy Very Bad Skyline Problems
Ok where do i start i swaped a car for a gts-t m-spec skyline its got a standard rb20det in it. i drove the car for all of about seven hours then it started to miss real bad every time i hit boost. so i suspected coils and/or ignition module i replaced both but no change. so i pulled out the plugs to find each one had melted the tips off. i brought new set of plugs it ran fine when i replaced them. Then i stupidly put regular 91 octane fuel in it not relising (half asleep) relised what i had done after filling the tank so i took it for a drive to see if it would effect it badly or not. IT DID it droped a cyl half way down the road. i took it to a mechanic who discoverd it had burned a pretty hole through the no.6 exaust valve so i had the valve replaced and iv just got it back but it still has a miss in the 3-5 rev range then it smooths out ive had the injectors and coils tested and they are mint. i still have no idea what it could be any help would be great cheers.
Get Some Bog And Fix Your Turbo
Lanzy61 is offline   Reply With Quote
Old 06-06-2005, 03:17 AM   #2
huracan0613
huracan0613's Avatar
Re: Very Bad Skyline Problems
Have you tested the airflow sensor yet? if not, do that before it's too late.
That's what I drive to work everyday, man.....I love it!
huracan0613 is offline   Reply With Quote
Old 06-06-2005, 03:06 PM   #3
Lanzy61
ok i will try ill keep u posted
Old 06-08-2005, 04:54 AM   #4
Lanzy61
tested air flow meter came back fine but in my travels i found 3 cracks in the sparkplug (porsiline bit) going to change plugs i will update tomorrow
Old 06-08-2005, 05:53 AM   #5
GTES-t
GTES-t's Avatar
Seeing as you have melted spark plugs, burned a hole in a piston and now cracked a spark plug, those are all tell tale signs of running to lean and/or overboosting. What boost is it running (keep in mind to check out the boost gage source pressure location/plumbing), what mods have been done, etc.
I would expect that you're overboosting, which is causing the missing, and leaning it out which is causing the various parts melting/cracking.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
GTES-t is offline   Reply With Quote
Old 06-09-2005, 01:03 AM   #6
randominsanity73
Send a message via MSN to randominsanity73
*screams* I can't believe you put 91 in it . I really don't know what to say to that. Jap cars were designed to have much higher octane levels in their cars (I think they have 102 there??) than what aus & US offer, which is why you MUST have the car tuned when you get it. Leaning out and/ or over boosting is going to destroy your engine pretty quickly. I personally would take it straight to a performance workshop with a dyno and have it tuned. Check what levels the boost is set to, I would reset them to my own.
Whoever said anything's possible never tried slamming a revolving door.
randominsanity73 is offline   Reply With Quote
Old 06-09-2005, 02:23 AM   #7
Lanzy61
The car is running standard boost (12.5psi) and is prteey much standard pod filter and heat sheld the car is running lean as i found out today i put it on the fuel analyser and the were the results
AT IDLE
co .17%
co2 12.0%
hc 122ppm
02 3.73%
air/fuel 17.5 to 1
so shes running pretty lean after more problem solving we found more than 5 vaccume leaks which is making it running lean will keep you posted
cheers
Old 08-04-2005, 06:47 AM   #8
Teaz
Teaz's Avatar
i doubt its gas since all they have at misawa is 92. i put octane booster in there every once in awhile
*inappropriate sig*
NO ADVERTISING
Teaz is offline   Reply With Quote
Old 08-06-2005, 05:50 AM   #9
RazorGTR
Skyline Man
RazorGTR's Avatar
Your lean problem is most likely caused by a dying fuel pump, which is a common problem. I'd replace it with a bosche 044 pump. Check your fuel pressure at the fuel pressure regulator also. You need to have a min of 35 psi under boost in standard trim.
AFM's can "check out fine" and still be a problem. Dry solder joins are a common problem with them.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
RazorGTR is offline   Reply With Quote
Old 08-08-2005, 07:07 PM   #10
Doughnutdemon
Doughnutdemon's Avatar
Re: Re: Very Bad Skyline Problems
Standard boost for a GTS-t RB20DET is 7 psi. 12.5 is pushing it.
Doughnutdemon is offline   Reply With Quote
Old 08-09-2005, 04:41 AM   #11
GTES-t
GTES-t's Avatar
standard boost is .7 to .8 bar, which is 10 to 11.6psi. 12.5 is a bit high, but well within limits. A stock RB20DET can take 1 bar (14.5psi) safely.
1994 Isuzu AMU
Old 11-16-2005, 06:26 PM   #12
Skyline_GTR
Couple of things to do/check...
1) Change the fuel filter...
2) Never put in 91 octane, try for 94
3) Your boost is kind of high... you risk blowing #6 Cylinder... (common)
4) Reset your ECU, it may have been tuned for more octane.
This section has a lot of helpful info... see the PDF's...
http://www.jdm-imports.com/skyline_specs.html
Skyline_GTR is offline   Reply With Quote
Old 12-19-2005, 04:44 AM   #13
nissan_r33_gts-t
Send a message via MSN to nissan_r33_gts-t
you keep talking about PSI... what is it ?
nissan_r33_gts-t is offline   Reply With Quote
Old 12-19-2005, 12:58 PM   #14
GTES-t
GTES-t's Avatar
PSI is Pounds Force Per Square Inch (lb/in^2), which is a pressure measurement mainly used in the US but also in some other areas.
1994 Isuzu AMU
