Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 11-25-2005, 10:58 PM   #1
smales09
Heater
Dealership says heater working fine, but does not blow hot air. Any suggestions?
smales09 is offline   Reply With Quote
Old 11-25-2005, 11:21 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Heater
A little more info would help.
Year make and model trans and engine and mileage?
Is it under warranty?
Have you checked water/coolant level?
Is the engine running at right tempture?
What temp does the gauge say?
MT
Old 11-26-2005, 08:00 PM   #3
Bads Crew
Bads Crew's Avatar
Yes give us more details. I am going around with my dealer on my 2001 S-10 Crew. I have a gurgling sound in my heater core that they say is normal but I think the Dex-Cool is screwing up my core. There are some know problems with trany fluid sucking into the vacumm lines on the 4WD models and causing vent problems.
Bads Crew is offline   Reply With Quote
Old 11-27-2005, 08:59 AM   #4
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Heater
Acid Flush your cooling system then replace with green and change your rad cap..(even if you go back to dex, change your rad cap, that should cure the gurgling)
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
Old 11-29-2005, 11:07 AM   #5
smales09
Re: Heater
Sorry, its a 98, 4WD model. the running temp is fine, as well as the coollent level. The fan just blows cold air. Thanks
