Go Back   Automotive Forums .com Car Chat > Mazda > 626/Capella/Capella Wagon
Old 07-21-2006, 04:15 PM   #1
gogi
1988 626 2.2 4dr auto non turbo ignition radiator fan heater fan problem
Hinew to the forum,live in Northern NJ
GF had an accident and took out the front ignition relay and heater fan relay.I replaced them with 30 amp generic wired as follows
Relays are pre wired with socket.Relay wires are colored as follows
Blue (30)
Green (86)
Brown (85)
Yellow (87)
Red (87B)
The igntion is wired to the relay "Car wire Color first"
Black to Red (87B)
Black & Red to Yellow (86)
black & Red to Green (87)
Black & White to Brown (85)
Yellow to Blue (30)
The radiator fan still only works if the sensor is disconnected and the key is on?
Is this wired correctly?
The Inside heater fan relay is connected as follows (car wires first)
Black to Green (86)
Blue to Blue (30)
Blue & Red to Yellow (87)
Yellow to Brown (85)
Is this wired correctly,inside fan doesn't work yet.
Also near the firwall coming out of the driver side fender is a 4 prong connector that has wires colored
Black&Red
White&blue
White&Red
White&Yellow
It is not connected to anything but the body shop use the hot to jump the radiator fan to go on ALL the time when the ignition was on because they didn't replace the destroyed relays.What is this for?Does it have anything to do with the problems, no radiator fan no heater fan, and the car starts in Neutral or drive?
I have a new head and valves $1500,New timing belt and water pump $530,New tires $240,new exhaust $275,and don't want to junk it.The dealers don't want to work on itand the car really drives well.Also prior to the accident she was getting 30-32 MPG now it's down to 20-23(is it ruunning in closed loop?even though the CEL insn't on?)
Sorry for the many questions and long post,but I've been fighting this for a year.
gogi is offline   Reply With Quote
