Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-05-2005, 10:14 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
1997 Crown Victoria PI
I am looking at purchasing a 97 Crown Vic PI. i was wondering if there is anything i should be looking for, as in engine problems, suspension, anything that usually goes wrong.
i also was wondering about a couple things on the police interceptor package, ive heard that they have a 200Amp Alternator, is this true, also what other improvements o thay have over a normal crown vic? i havent been able to find much information on the web.
And is the '97 model OBDII compliant, it should be but im jsut checking.
Old 12-05-2005, 07:37 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1997 Crown Victoria PI
The ball joints and front suspension bushings are the weak points on the front suspension. Usually engine problems are mostly the composite intake cracking, DPFE sensors, and MAF sensors.
The 200 amp alternator was not commonly available until 2003 or 2003 on most CVPI's. 97's had a 130 amp stock.
Yes it is OBDII compliant.
If the vehicle has had good routine maintenance it should be reliable for quite a while. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 12-05-2005, 10:36 PM
damn i want that 200AMP, im also looking @ a 1970 lincoln continental, i have a thing for big cars. im not sure about the electrical system in the Lincoln though.... ima have to check on that
Old 12-06-2005, 12:38 PM
way2old's Avatar
TOKEN HILLBILLY
There is a company in Virginia that makes a retro-fit 200 amp alternator that will bolt on. I don't know the name or site though. If I can get our parts dept. to loosen up on info, I will post it for you.
Old 12-06-2005, 10:04 PM
fleettech fleettech is offline
american armature www.americanarmature.com 563-323-7994 ext 107 lists a nitro series for all police vehicles
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 12-07-2005, 07:07 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks fleettech. Saves some begging.
