Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 08-01-2008, 03:44 PM   #1
ironman2712
truth about cleaning engine compartment
hello again, yesterday i poped up the hood in my cheroo, and i ooked at this 20 years old mess-entire compartment is covered with all this dirt sh.., -oil, dust, sand,and everything else you can imagine. That gave an idea(a mission)-wash it off, with some chemical staff and pressure rinse---any of you has ever done that before????????????????is it safe for wiring and electrical circuits????????????????please advise
ironman2712 is offline   Reply With Quote
Old 08-02-2008, 11:32 AM   #2
AlohaBra
AlohaBra's Avatar
Re: truth about cleaning engine compartment
I have washed off the engine. I do not recommend pressure washing. Stay away from the electronics. You might have to dry the ignition...dist. cap and plug wires etc. Hand wipe the greasy areas with a rag and brakekleen.
AlohaBra is offline   Reply With Quote
Old 08-02-2008, 12:55 PM   #3
Saudade
Saudade's Avatar
I also would not use high pressure in the engine compartment. Disconnect the TPS and IAC and cover them with a plastic bag. Spay some WD-40 in the connectors before you plug them back in. Also be gentle around your AC clutch (if you have one) and your alt.
I do this regularly. Since it's my DD it doesn't get too bad here in SoCal. I have a shop vac that has a blower mode. Once I'm done washing it, I fire it up and use the vac with the concentrator to blow as much water off as I can.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Saudade is offline   Reply With Quote
Old 08-10-2008, 10:48 AM   #4
dugg365
yes WD-40 is good for water dispersant. like the other posts have said, avoid spraying the electronics. i have done mine 3 times at a carwash that allowed it. and once at home with the hose. it took that many times because i did not use any chemicals, just straight water. gunk foamy engine brite is a pretty good de-greaser, also simple green. although i have not used them on this vehicle.
dugg365 is offline   Reply With Quote
