Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
View Poll Results: Next Cheap mod
White face gauges 0 0%
Front and rear strut bars 2 18.18%
Aftermaket BOV 8 72.73%
Short throw shifter 1 9.09%
Voters: 11. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 09-25-2005, 07:36 PM   #1
complex_eclipse
Send a message via ICQ to complex_eclipse Send a message via AIM to complex_eclipse Send a message via MSN to complex_eclipse Send a message via Yahoo to complex_eclipse
Red face New Car mods
Alright I just came into owership of a 1992 Laser AWD Turbo 5-speed. The local used car dealer took it on trade then after a couple weeks and a lot of messing around i bought the car for 200 bucks. Ok here comes the bad news the tranny slips out of 1st gear if your just idleing around but if ur accelerating or decellerating is usually stays in gear. The clutch is completely gone but before the previous owner traded it in he went on ebay and bought a XTD Stage 3 clutch kit . While I was dealing with the dealer the ignition key was locked up the key wouldn't turn to at all (the main reason i got the car so cheap) i contacted the local dodge dealer and was told that a new lock complete lock assembly would run about 300 cuz the previous owner must have taken it apart and it is all smashed up he had to have taken the actual switch out of the back of it and been starting it with a screwdriver .
I have never heard of XTD clutchs before it seems to be ok, i suppose. It's a 6 puck copper/ceramic friction material and it comes with the throught bearing alinment tool and pressure plate. Anyone have any experiance with this company cuz I don't know if i should use it or buy and oem clutch kit. i Have searched over the net and couldn't really come up with and info for this clutch company.
I also don't know if i should buy a new flywheel or if i should have some one turn it down when we put a new clutch in my dad's pichup we were told if we turned the flywheel that we had to shim it back out or the clutch wouldn't last. The chiltons manual i have for the car say it can be turned but doesn't saw anything about shimming it back out.
I just finished building a non turbo front wheel drive eclipse so i do know my way around these cars but on the turbo front i am kinda new.
I want to give the car a little bit more power but i'm on a very tight budget since winter is coming and i got my hours at work cut.
Cars:
~1992 Mitsu. Eclipse non-turbo Front wheel drive Automatic
Full Agressor body kit
Cold air intake K/N filter
Naxous Racing Pipe
White Face Gauges
Megan Racing strut bars (Front and Rear)
Customized Red interior
~1992 Plymouth Laser All Wheel Drive Turbo 5-speed
Turbo back Dynomax 3-imch Exhaust
Blitz Turbo Timer
Butchered Intake box with K/N Filter
complex_eclipse is offline
Old 09-26-2005, 01:50 AM   #2
SLoe
SLoe's Avatar
Re: New Car mods
I don't see a manual boost controller and boost gauge on your list. None of that stuff in your poll will give you more power, and the 1g BOV is good enough anyway so I wouldn't get an aftermarket.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
SLoe is offline
Old 09-26-2005, 07:01 PM   #3
complex_eclipse
True a 1g bov may be fine but an aftermaket one sounds soo much better and what is the point of a boost gauge when there is one right in the gauge cluster but a boost controller i never really thought about.
Yes i know none of the mods in my poll would give it more power but in order to make more power i would prolly start with a wideband 02 sensor and gauge then a fuel rail with pressure regulator bigger injectors and maybe a fuel pump for the fuel side. As for the air side the boost controller like was stated before would be a good start then an aftermaket wastegate and a frount mount intercooler wich would give me alot more power but the name of the poll is cheap mods if money was no object yea i've already stated the way i would go.
Cars:
Naxous Racing Pipe
White Face Gauges
Blitz Turbo Timer
Old 09-26-2005, 08:15 PM   #4
l_eclipse_l
l_eclipse_l's Avatar
Re: New Car mods
The 1g BOV has been proven to hold 20+ psi of boost on a regular basis. And it's cheaper than a nice aftermarket. You can pick one up on ebay for around $75.
The stock boost guage is a POS. Aftermarket boost gauge is gonna be a necessity if you plan on modding for performance.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
l_eclipse_l is offline
Old 09-27-2005, 06:42 AM   #5
SLoe
SLoe's Avatar
Re: New Car mods
Well the most "bang for the buck" is the boost controller then. You will get more power and it will not cost more than the other things on your poll. You could even make your own if you wanted ; )
SLoe is offline
Old 09-27-2005, 07:56 AM   #6
complex_eclipse
i have heard of building you own boost contoller and i know what i need and what i need to end with but the inbetween area's are a bit gray any one that might be able to give me a shove in the right direction would be great
Thanks TJ
Cars:
Naxous Racing Pipe
White Face Gauges
Blitz Turbo Timer
Old 09-27-2005, 12:35 PM   #7
SLoe
SLoe's Avatar
Click here for homemade MBC
There is the info, but there are some really cheap ones you can just buy and I don't know if I would go to the trouble of building one. Unless you just wanted to say you did it. Pay attention to the part where it says, "This is the sort of mod that can destroy a turbocharged engine in less than a heartbeat. If you do not fully understand any aspect of this system, DO NOT install it on your vehicle or anyone else's vehicle."
I started with a cheap ass e-bay type MBC, and it worked just fine. Get a boost gauge first, they are not that expensive either.
SLoe is offline
Old 09-28-2005, 04:48 PM   #8
viet_boiiiii
viet_boiiiii's Avatar
Send a message via AIM to viet_boiiiii
Re: New Car mods
Boost gauge + Boost controller = around 70-100 bucks total... for around 10-20 hp (t25) and depending on what turbo you use and how many psi you are running.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
viet_boiiiii is offline
Old 09-28-2005, 11:23 PM   #9
gthompson97
gthompson97's Avatar
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: New Car mods
that mod list isn't the greatest list i've seen, actually it's pretty poor. you wouldn't need a new fuel rail on the t25, nor would you need a different intercooler or an aftermarket wastegate. there are a ton of things in between that you'll need. for a good upgrading list, see: http://dsmtuners.com/tech.php
95 Talon TSI AWD
97 Eclipse GST
gthompson97 is offline
Old 09-29-2005, 12:07 AM   #10
viet_boiiiii
Re: New Car mods
Your list should be
1) Boost controller + boost gauge
2) 16g turbo (bolt on for 1gens)
3) hacked 2nd gen intake
4) or aftermarket intake
-magnaflow catback
Old 09-29-2005, 03:56 PM   #11
complex_eclipse
Re: Re: New Car mods
Originally Posted by viet_boiiiii
Your list should be
Why in the fuck would i go spend my money on a different turbo when i can have the exhaust houseing bored out and have a turbo that will push over 500 horse at like 30psi
Cars:
Naxous Racing Pipe
White Face Gauges
Blitz Turbo Timer
Old 09-30-2005, 09:54 PM   #12
londa hover
you guys say the first thing should be boost controller?? You know that would require tuning above stock boost right?
londa hover is offline
Old 09-30-2005, 10:42 PM   #13
Turbodog97
Just a Neon
Turbodog97's Avatar
Re: Re: Re: New Car mods
Alright number one if you want anywhere above the factory 210 hrpswr you NEED a boost gauge. The one in the cluster isnt' accurate worth a crap. Also, I don't know what turbo you are talking about having but if it's your factory 14b it's not good for 500 hrspwr/30psi. My EvoIII is only good for about 395...You would have to have a 20g or something humungous like that. And porting that manifold won't be that significant either. I did mine and was dissappointed . And also a front mount will make it slower until you put in a larger turbo
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Turbodog97 is offline
Old 09-30-2005, 11:06 PM   #14
viet_boiiiii
Re: New Car mods
Gosh calm down... just trying to help someone. So a white face gauge is a better upgrade than a 16g turbo.. ok.
-magnaflow catback
Old 10-01-2005, 05:04 AM   #15
SLoe
SLoe's Avatar
What does that mean?
Gosh calm down... just trying to help someone. So a white face gauge is a better upgrade than a 16g turbo.. ok.?
Good one
SLoe is offline
Closed Thread
