Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-14-2005, 12:04 AM
OldsBuickGuy82 OldsBuickGuy82 is offline
Installing lock cylinder/ignition...Help
Hi,
The key broke off in my 1992 CV ignition and will not come out, so I went and picked up another lock cylinder at a used auto parts store.
Can anyone tell me how to install it step by step, including how to remove the plastic coverings that go around the base of the steering wheel without breaking it?...
Thanks
Any advice is welcome.
Old 10-14-2005, 07:40 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Installing lock cylinder/ignition...Help
If you can use the broken key to turn the ignition to "on" position, there is a small hole that you can insert a small screwdriver in to release the lock pin. Then the lock cylinder will pull out.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-14-2005, 11:24 AM
So, I don't have to remove the plastic from the wheel at all?...Should I disconnect the battery before I do anything?...What position should the new lock cylinder be in when I insert it?...On or off???
Thanks
Old 10-14-2005, 04:02 PM
way2old's Avatar
TOKEN HILLBILLY
You don't need to do anything. The new cylinder needs to be in the "on" position. Slide it is, turn it to lock, remove key and the cylinder will lock in place.
Old 10-14-2005, 09:49 PM
It worked, had a bit of fooling for a few minutes, but it went in pretty smoothly.
Thanks for your help
Old 10-15-2005, 05:33 PM
way2old's Avatar
TOKEN HILLBILLY
Glad you got it.
