Old 10-01-2005, 01:44 PM   #1
bigdinz
bigdinz's Avatar
A/C recharge question
Will it kill the A/C system if I don't evacuate it first? I did replace some seals, so it was open to outside air.
bigdinz is offline   Reply With Quote
Old 10-01-2005, 04:30 PM   #2
97BlazerDude
97BlazerDude's Avatar
Re: A/C recharge question
No. I replaced the compressor and did not evacuate prior to recharging, and my AC system did not die or explode, yet (it has been a few months now.) It is not super dooper cold, but it never was really cold anyways.
I can wear a blazer. I can drive a blazer.
97BlazerDude is offline   Reply With Quote
Old 10-01-2005, 07:50 PM   #3
jsgold
If you were converting from R12 to 134 you would be killing your system for sure. If not you should be OK. I had to disasemble my son's Corsica a month ago and just recharged. Still OK.
I used to be indecisive, now I am not so sure.
jsgold is offline   Reply With Quote
Old 10-01-2005, 08:09 PM   #4
blazee
Problem?
blazee's Avatar
You can refill it and your system will be ok. You will however see a lot better performance out of it if you have a vacuum pulled on it to get out all the air.
blazee is offline   Reply With Quote
Old 10-01-2005, 08:13 PM   #5
GMMerlin
I know stuff
GMMerlin's Avatar
If your A/C system was open for any time, moisture will collect inside the system. The purpose of evacuating the system is to remove moisture to prevent internal damage.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 10-01-2005, 08:32 PM   #6
mike2004tct
mike2004tct's Avatar
Re: Re: A/C recharge question
If you have a problem loading the freon, just loosen the fittings at the compressor ever sooo slightly, enough to let air out (1/2 to 3/4 turns) for about 10 seconds. (let the air out- not the oil or all of the gas).
If you have oil spraying out, you loosened too much.
mike2004tct is offline   Reply With Quote
Old 10-01-2005, 10:08 PM   #7
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
i evacuated mine first just to be sure.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
Old 10-01-2005, 10:28 PM   #8
tom3
Refrig. is held in the oil for a short while and continues to boil off, this will keep air and moisture from getting in the system to a large extent. Air and moisture over time will create an acid compound in the system that will eat it up, so try to get it done pretty quick.
tom3 is offline   Reply With Quote
Old 10-01-2005, 11:23 PM   #9
bigdinz
bigdinz's Avatar
Thanks all. FYI--only replaced a few seals on top end,was open just long enough to quickly swap them out. system was and is r134.
