Old 09-06-2005, 07:40 AM
czm400r czm400r is offline
SeaFoam
I have used SeaFoam fuel as a system cleaner as long as I can remember, Why I don't know but I run a can thru the tank every 20-25k miles and have had no fuel related problems. The can does say that it can be used in the crankcase oil as a cleanup. Anyone use this in the engine before?
Old 09-06-2005, 08:20 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: SeaFoam
Seafoam is supposed to be some good stuff, I've never used it though, Do a SEARCH on seafoam, all of your questions should be answered then.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 09-07-2005, 03:15 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: SeaFoam
Heard of lots of people using it in their oil system as a slow flush.
1/2 a can in the gas tank, rest of the can in the crankcase, drive 500 miles and dump the oil and do an oil change.
Old 09-07-2005, 09:57 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I have yet to use seafoam, I think I heard it fouls plugs easily but I could be wrong. I really like Marvel Mystery oil in the gas tank and the price is unbeatable! Autozone $2.99 for a 32 ounce bottle and per 10 gallons of gas you use 4 ounces of Marvel Mystery oil. Basically get 4 treatments out of it. I like it.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-07-2005, 12:10 PM
BlazerLT's Avatar
AF -Advisor
Re: SeaFoam
Seafoam will foam the plugs when you suck it through the PCV line for combustion chamber cleaning.
Old 09-09-2005, 06:17 PM
Tangent Tangent is offline
Re: SeaFoam
I can't say I've ever heard of something "foaming" the plugs before...
Old 09-09-2005, 10:46 PM
BlazerLT's Avatar
AF -Advisor
Re: SeaFoam
It doesn't foam, it fogs the cylinders and removes excess carbon.
This can also be done with water which is what I use seing there is no residue.
Old 09-11-2005, 01:22 AM
Re: Re: SeaFoam
Yea didn't you get your engine steam cleaned or something? Is that same day service you can pick up, or do they drop if off in a box pressed and folded??? hahaha I am cracking up!
K&N Air Filter
Old 09-11-2005, 12:00 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: SeaFoam
sea foam, your using it to often, but you are useing a great product... every few oil changes/ transmission services, 500 miles prior, put half a can into the fluid, and it helps thin it out and degrease the internals
Old 09-11-2005, 06:45 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: SeaFoam
It worked perfectly and didn't foul my plugs. Really happy about it.
Old 09-12-2005, 09:42 AM
Re: Re: Re: Re: SeaFoam
How do they do it and what does something like that cost?
K&N Air Filter
Old 09-12-2005, 10:08 AM
BlazerLT's Avatar
AF -Advisor
Re: SeaFoam
do a search for water cylinder decarbonization
Old 09-12-2005, 10:46 AM
Re: Re: SeaFoam
Ok cool thanks
K&N Air Filter
