Loss of Power on hills
I recently have been having a loss of power on my 1988 (4.0L) 4x4.
It only happens when I am driving up a hill or grade. It will down shift but still it does not have the power that it once had. I have recently replaced the TPS, Crank sensor, spark plugs, wires, distributor cap and coil. There is a idle motor probe in the side of the carberator (for the life of me, I can't remember the name of it though) that I removed and cleaned with carb cleaner and returned it to the slot. I am thinking that that might be my problem, but I am not sure. After cleaning it I read that much care should be takin not to move that part around to much. I don't remember moving it around too much but who knows. I looked for a loose or broken vacuum line but found none. The idle is a bit rough but runs okay.. high idle at start up (revs then drops to normal). I tried the computer reset but still the problem. Does anyone have suggestions????? |
Re: Loss of Power on hills
How many miles?? Mine is a 97...with 125K but with fuel injectors... used to be a mechanic tho.... How about clogged exhaust or clogged Cat (catalytic convertor)? How about a vacuum test on engine while driving? Other checks you might consider are compression test and timing chain stretch. |
HEY THERE! Mine's an '88!
![]() 4x4: Did you adjust the TPS to specs when you replaced it? |
Re: Re: Loss of Power on hills
Have you changed the fuel filter? Might want to check fuel pressure also.
Re: Re: Re: Loss of Power on hills
I got the correct voltage. |
the 88 has fuel injection as well, I think he was referring to the throttle body.
The FSM says it should be .2 volts for an auto trans fully closed.
A manual trans should read 4.6-4.7v wide open. |
Have you changed to larger tires recently?
