Old 08-24-2005, 09:25 PM
drdd's Avatar
drdd drdd is offline
is this a dumb question? battery drainage
So I've noticed, when I first turn on my truck in the morning, the volt meter rises fairly quickly to 14 when I have all the elec accessories off (lights, radio, AC). However, when I start it up (particularly with the AC on), the volt meter takes longer to get to 14 (maybe 4 - 5 seconds).
Will I save battery life if I start the truck with the AC off as well as other elec load off?
BTW, My battery and alternator are brand new.
Old 08-24-2005, 09:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: is this a dumb question? battery drainage
Yes, let you truck warm up before you turn the AC on.
Plus starting it with th AC on is asking a lot.
Leave everything off until you are driving away.
Never load a system a idle.
Old 08-24-2005, 10:11 PM
drdd's Avatar
Re: Re: is this a dumb question? battery drainage
Thanks BlazerLT. Thats what I figured but I thought I'd double check. I do disagree with one thing you said ... " ... starting it with the AC on is asking alot ...". God bless the wizards at GM. I don't think its too much to ask for a vehicle to handle all elec loads at all time. It's not uncommon for people to start their cars with the radio on, the lights, and the AC or heater or any combination of these. GM should have addressed this in the owners manual. OR they should've given us a space-shuttle type checklist to start the vehicle! first the ignition, then lights, then AC, then set for lift-off!
Seriously though ... enough venting! Haha!
So, why no full elec load at idle. Isn't this when the truck ought to be able to handle its maximum load? when its not driving ... or, are you saying that, in general, we should avoid putting the full elec load on our trucks in general because their not designed for full elec load unless there are increase rpms?
Old 08-25-2005, 05:47 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
My AC compressor is delayed on another GM car 2000 year model . It does not cut on for at least ten seconds. And all assessory power is cut off too Which compensates for that first start load on the battery. I know a previous 97 year GM car also did that . If your compressor is being turned with the engine at startup , You may have another issue malfunctioning . Hope not , We don't need more to write about . Rob
Old 08-25-2005, 05:55 AM
Rmbodie's Avatar
Also even at idle , with a volt meter (not the dash gauge) , if you have 12 volts or more , your battery is still being charged . The alternater is carrying the full load . But I am sure this will cause much debate . Rob
Old 08-25-2005, 08:30 AM
Allbert Allbert is offline
One failure mode I know of from my work as a blower motor warranty engineer is the permanent magnets in some motors can be de-magnetized by a large sudden inrush of current, such as occurs when you key on with your fan control on high during cold weather. This de-magnetization degrades performance of the motor and can lead to failure.
Old 08-25-2005, 12:21 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
i agree with blazerlt i mean its kind stupid to start ur car with the ac on or blower motor on full blast cuz it puts a hevay load on the engine right from the start plus in the winter it will only blow cold air for a lil bit makeing u colder and in the summer it will blow hot air imediatly for a lil bit. hope this helps also when ur driveing the idle is a lot faster thus meaning the altinator is making alot more power to supply ur acceserys to the fullest
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 08-25-2005, 01:08 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: is this a dumb question? battery drainage
Sure, it can probably hold it, but you are putting maximum stress on your electrical system when the alternator is at its lowest spinning rate.
If you want to use the AC, put the fan on low and hit the recirculate button to cool the cabin off faster with as low of a load at idle.
