Old 08-15-2005, 02:31 PM   #1
Elemental™
Send a message via AIM to Elemental™
Unhappy Turn signals
My turn signals arent working but my hazards are. I cant find the flasher thats supposed to be clipped to the steering column, and i really dont want to pull apart my steering column because who knows what can happen. I think its the flasher but im not absolutely sure. Is there another way to reach the flasher without pulling the steering column apart?
Elemental™ is offline   Reply With Quote
Old 08-16-2005, 07:27 PM   #2
Rubicon1
Check to see if your brake lights are working also, the center mounted one should be working anyway. Then try to wiggle the signal lever. If this make them come back on intermittenly, then your turn signal switch is probably going bad. A very common problem with the 95-01 Lumina's.
Rubicon1 is offline   Reply With Quote
Old 08-17-2005, 02:58 AM   #3
dksob81
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Turn signals
I am having this smae problem in my 1990 lumina.
Did you find a fix?
dksob81 is offline   Reply With Quote
Old 08-17-2005, 04:33 PM   #4
Ofnarcr
Re: Turn signals
yeah my 90 lumina does that but something strange happened, smoke started coming from the stearing column, a short I think.
Ofnarcr is offline   Reply With Quote
Old 08-18-2005, 10:18 AM   #5
bstrom1953
Re: Turn signals
Brake light probs are often traced to the turn signal switch. The switch is probably worn out. Some guys say you can take the switch out and bend the contacts a little to make them touch again. I found that mine had a couple of plastic hold down tabs that were worn half-way through. This allowed the rotating switch portion to lose contact with connections under it.
I went to NAPA and bought a Haynes manual ( you need one anyway if you are going to work on your car yourself) and a special tool ($8) to take the steering wheel off. The switch was $74, so I fixed my old one instead.
You can do it!
bstrom1953 is offline   Reply With Quote
Old 08-18-2005, 05:28 PM   #6
Elemental™
The brake lights work, all of them. Its not a 95-01 its a 92, picked up for 700 bucks The switch isnt giving anything, i think the flasher isnt even there at all, that maybe the problem? Oh and trust me, of course i got my haynes repair manual. Thing helped alot to go from a car that had to be towed, to one that runs like a champ.
Old 08-22-2005, 10:26 AM   #7
helped1
I have a 92 lumina. The flasher unit was on top of the steering column at the bottom end of the column, cab side, by the fire wall!
helped1 is offline   Reply With Quote
Old 08-23-2005, 12:39 AM   #8
zephram22
zephram22's Avatar
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
A couple things...
Hazards and turn signals are not related electrically. Wekk, not quite. Point is, I tried to put an led turn signal in my 99 and ended up blowing every fuse has had to do with light.
Turn signals and hazards run off of two compltey different circuits. Replace the fuses for the turn signal markers, etccc.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
zephram22 is offline   Reply With Quote
