01 Windstar front end buzz,hum, noise
My 01 Windstar has developed noise in front which is not tire hum but sure sounds like it. Sounds like it has big mud grips on front. Put new tires on front which I needed in any event but noise did not change. Checked for possible exhaust leak but could'nt find any. Noise gets louder as speed increases. Noise level steady thruout upshifting of transmission and does not decrease any when tach falls upon tranny shifting to higher gear. Only gets louder as speed increases and wheel revolutions increase. Noise is a loud hum/buzz and seem to be able to feel it in steering wheel, but drives well. No noise increase on turns. Noise decreases as speed decreases. Possible front wheel bearing? Any feedback would be helpful - thanks.
This sure sounds like bad wheel bearings. Not sure what FMC wants for new bearing/hub kits these days. I believe they *usually* can be had for around $50 a side, plus a couple hundred $ for labor to have them changed out. This would also be a good time to do front brakes if you need them. You'll have everythig apart anyway.
G/luck! Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Re: 01 Windstar front end buzz,hum, noise
01 Windstar front wheel bearing/hub assbly. priced @ $125 ea. from parts retailer - sounds kind of high but have never done this on a fr.whl.drive so I am in the dark. Thanks for the reply!
sherm42 did wheel bearing fix your noise?my windstar has exact noise
that you decribed.I'm leaning more toward the transmission.we jacked van up and held each wheel individually and spun the other to 60 mph and noise appeared to be the same on both sides.(never had a wheel bearing noise that would not change sounds when you swerve left or right)and like your van it only changes with speed.hoping for some help!!!Thanks |
Re: Re: 01 Windstar front end buzz,hum, noise
Windstar bearing removed
sherm42,i removed right ft wheel bearing today(fairly easy job 1/2 hr)took bearing apart found some small pits on outer race not real conclusive(hoping that was it!!)Had to order part at NAPA $114,AutoZone $122 will have it in the morning.Hold'in my breath!!Thanks
[quote=sherm42]My 01 Windstar has developed noise in front which is not tire hum but sure sounds like it. Sounds like it has big mud grips on front.
Had the same problem with my 2001. I described my noise sounded like a jet plane was geting ready for take off. It was a bad wheel bearing My van was at the dealer anyway for another problem ( replace the cluster, battery drain). The dealer charged $140 a side. I only needed the driver side replaced. Before I had the bearing replaced I looked it up in my service manual and the bearing needed to be compressed. Meaning over my head. |
Mech. drove & feels very sure it is pass.side bearing. Also let me know that he will be a couple of days in coming up with that part. His parts suppliers told him it is in demand. I am going to have him do the repair next week sometime. Hope he is right. Thanks
timk1
Congrats on your repair! Did you require a puller to disassemble the hubs ... or did the bearings just come out easily? Wait a minute, did you replace hubs with bearings already installed? Thnx for the feedback! |
one bolt on bottom ball joint and axle are removed there are three bolts that on the bearing/hub.Knock out hub/bearing with hammer.Only special tools were a 40 torx socket,1 3/16 deep well socket(probably metric)and a few basic metric sockets.Thanks |
One of better forums I read. Thanks for all the good info. I might need this later on... on my 00 SEL.
Sherm42, how did this turn out? I also have an `01 that's making the same sounds. I'm thinking about replacing the bearings/hubs myself.
Sherm42- how many miles are on your '01? Just curious. (My '01 has just about 60,000)
