Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-16-2005, 10:47 AM   #1
GinnyA
Unhappy 2000 JCG Won't Start!
I have a 2000 Jeep Grand Cherokee Laredo and it seems to be having some electrical problems. I went to leave work yesterday and it wouldn't start at all. All the gagues were going crazy when I tried even after I took the key out of the ignition. It was also making a clicking noise. It will start if you jump it but if you turn it off it will not turn back on. We got it started so I could go home but on my way the odometer started flashing on and off and my speakers were making a popping noise. Anyone have any ideas what could be causing this?
GinnyA is offline   Reply With Quote
Old 08-16-2005, 12:24 PM   #2
dksob81
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 2000 JCG Won't Start!
a bad battery has been known for causing the guages to go crazy (jumping all about) like you describe.
dksob81 is offline   Reply With Quote
Old 08-16-2005, 12:54 PM   #3
GinnyA
2000 JGC Won't Start!
That's what I am thinking too because once you jump it it stays running. If it was the alternator it wouldn't stay running, would it?
Old 08-16-2005, 01:03 PM   #4
dksob81
your right it wouldn't remain running if it were the altenator.
Old 08-16-2005, 01:15 PM   #5
GinnyA
Smile 2000 JCG Won't Start!
Thank you so much for your input!! It's greatly appreciated!!
Old 08-17-2005, 09:30 AM   #6
GinnyA
Hey!! Just wanted to let everyone know that is was the battery!! Thanks for all your help!!
Old 08-17-2005, 09:00 PM   #7
Bob45
Question Re: 2000 JCG Won't Start!
Did the battery service fix the problem? My 1999 GC is in the shop with the same problem. I went to start it and the lights went out, then went dim -the gauges went crazy, and the there was a clicking noise from the fuse panel. I was able to disconnect and reconnect the battery cables to get it started.
The service shop has had it for 2 days and cannot find anything wrong with other than it needed a battery service. They said there may be bad connections. I am worried it is more of a problem than that. Is your jeep still working OK?
Bob45 is offline   Reply With Quote
