Old 10-30-2006, 01:08 PM   #1
Cailen
Pathfinder Audio Set ups
Interested in what people have got.. particularly what type of subwoofer enclosures people have used (and hopefully some pictures thereof), and what type of component speakers people might have gone with. I'm basically being told that if I buy a pair of components and put the tweeter in the A pillar where the tweets are now, that it won't sound very good.
I'm going to be purchasing a Pioneer P6800DVD, and I have a pair of JL 12w3v2-D4's that i want to install. I'm also pretty keen on fibreglassing the subwoofer enclosure.
Are there any other sites out there that might help me get a working concept?
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Cailen is offline   Reply With Quote
Old 12-04-2006, 09:32 PM   #2
Cailen
Re: Pathfinder Audio Set ups
So I just got the deck today. Has anyone here done their own installs? I'm hoping someone might have a dash layout or something I can look at. Anything I need to watch for?
Also where will I be passing the 12v wire through the firewall? Will I need to drill?
Old 12-21-2006, 09:59 AM   #3
Keg914
There is really nothing to it. I did a custom system on mine about a year ago. I have a pioneer head unit, 4 alpine speakers (all 5x7 to fit in the original speaker holes), a 10in JL sub, and an audiobahn amp pumping out 400 rms. The only thing I had a problem with, until I figured it out, was that if you are going to use the original wiring for the four speakers in the doors and on the roof, you have to make sure you connect the blue amp remote wire for those speakers. The original system in pathfinders have amps already built into them. The amps are located in the right rear cargo area. So unless you want to rewire the whole truck, just make sure you use that bule wire already set up for the amps. The blue wire is in the wireing harness with the rest of the speaker wires. Now, to use those amps and your sub, you have to rig it to where your amp remote wire and the other amps remote wire go to the same connector on your head unit. For the 4 gauge wire that I used to power my amp, I had to put it thought a small hole located in the front driver side firewall (real close to the battery). It was coverd by a small, plastic, black cap that could be easily pushed out. I had to bore the whole out slightly to get the wire to fit thourgh.
Keg914 is offline   Reply With Quote
Old 12-21-2006, 10:37 PM   #4
88pathoffroad
Send a message via ICQ to 88pathoffroad Send a message via AIM to 88pathoffroad Send a message via Yahoo to 88pathoffroad
I'd say that if you're that clueless have a shop do it for you so you don't screw anything up and end up with no dash lights, etc...
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc
Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
88pathoffroad is offline   Reply With Quote
