I know Primera Man has a nice polishing how to, but I've been using a product called Scratch X by Meguiars. It's about $8 and can be found at Wal-Mart, Target, and auto supply stores. It's too simple simple to use you won't belive your eyes.
You will need some wet/dry sandpaper, a cotton t-shirt, some cotton swabs for the hard to reach areas, and Scratch X. ![]() First, select a victim with some orange peel. ![]() Level any orange peel lightly by wet sanding with 2000 grit sandpaper. If it's a little heavy I'll start with 1500 and then 2000. In this pic the hood, nose and fenders have been wetsanded, and the grit washed away with some dishsoap and water. ![]() Now that we have a smooth, but scratched surface it's time for some Scratch X. A little bit goes a long way. Use very little to achieve the best results. ![]() Put a little bit on your rag and use small circular motions. Medium pressure is all you'll need. You will start to feel the shine under your finger as you rub. As you get a bit of a shine, switch to a clean part of the rag and buff it a bit. Rub some on..Buff it off.. and repeat until you get a nice shine. In this pic I have rubbed and buffed the lower 3/4's of the hood. ![]() You may find that after polishing it up you have to go back to your sandpaper and level an area some more. Just repeat the steps until you get a nice smooth shiny surface. ![]() It will take some trial and error, but once you figure out it really makes polishing fun!
Matt
i use the same stuff but i think 2000 grit is a little harsh. i use micro-mesh starting with 3200, then 3600, 4000, 6000, 8000, and finally 12000 grit. then lightly use Scratch X. but is is a good and easy to find product. i recommend it highly! remember also NOT to buff your model for at least a week until after painting. waiting 3 weeks is even better. And dont buff metallic or pearl paints unless you have clear coated them. it will dull the finish and make the flakes to large for this scale.
Friends dont let friends buy die-casts... "If it can't run 24hrs., it aint sh!t...." -me ![]() ![]()
Veyron showed me a chart comparing Micromesh labels to the US grit equivalent.
Using 2000 Grit Tamiya paper is somewhere between 4000 and 6000 micromesh cloths. Not to harsh really. This info is on the Micro mesh site. http://www.sisweb.com/micromesh/conversion.htm Micro-Mesh Size VS Grit Equivalent Comparison 1500 = 400 1800 = 600 2400 = 800 3200 = 1200 3600 = 1350 4000 = 1500 6000 8000 12000
Matt
Re: How to: Polishing with Meguiars Scratch X
Nice writeup CADguy. That's how it's done with other types of cutting/polishing compound too, doesn't have to be Meguiars.
Re: Re: How to: Polishing with Meguiars Scratch X
My Fotki Album |
Absolutely, all compounds are different in amount of cut and resulting smoothness. The latest Tamiya polishing compounds are a case in point, coming in three different degrees of harshness. I imagine Tamiya intended for the modeller to start with the hard and finish with the finish.
Re: Re: Re: How to: Polishing with Meguiars Scratch X
That one $8 tube has polished 24 cars so far, with about 1/2 left over. So there is a cost savings. One little tube of Tamiya compound is not cheap in hobby stores here in my area. If you can even find it. It works with minimal effort as mentioned. Other rubbing compounds I've used took some major work and elbow grease. Not rubbing as much or with as much force leads to less rub throughs. I've used Scratch X on enamels, and acrylic lacquers (Tamiya paints love this stuff) with great results. This particular car was sprayed with CobraColors clear. It is an acrylic lacquer as well, but dries much harder than Tamiyas clear. It sands and polishes very nicely.
Matt
Okay, okay, I'm convinced.
Will have to get me some.
I used by girlfriends face buff with similar results (other then the screming afterwards)
Great tutorial! kudos.
In Progress: FXX - test mule in CF 49' Mercury |
yes this stuff is amazing...it clears away scratches so well that it confuses me. The only problems that i've run across are when I used too much (learned that after reading this tutorial) and the results are hazy and not so shiny. Thanks for the tutorial CADguy!
sounds like you sold me on this, before i was using 3m rubbing compound which still works good but id like to try this one, now one more thing, do i have to still wax afterwards? and if not, is it still a good idea to wax afterwards anyways?, by the way, i use meguires cleaner wax to wax my models because i use automotive paint. thanks!
It is a good idea to wax the car to keep that shine!
Sold. good thing wallyworld is open 24-7.
It ain't cool 'till your wife hates it. Imagine a world without Alabama Recent builds: Rocket Bunny FR-S and stock BRZ Toyota bB Bro-style Civic K20 powered SiR converted EK WIP I build slowly and poorly.
Thanks for that tutorial, my favourite Veilside Porsche is looking very shiny !!!
Mike
http://smg.photobucket.com/albums/v149/aoshima/?start=0 |
