| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Past Z Car Forum Projects: Remixed
Alright, since the last thread has a bunch of crap on it and most your projects have changed quite a bit, we'll just start over.
Car: 95 Z32 Twin Turbo Project code name: "Various Evil ****" Goal: Various evil ****, to include a lag free 500-550 rwhp Drivablity date: June 2005 Completion date*: July 2005 Status: Behind original schedule, behind updated schedule, behind revised schedule, approaching 1 year mark, have given up on scheduling and am just trying to finish it - Everything except for the 530BB turbos, inconel manifolds and test/downpipes has been purchased. The turbos and inconels will be last as they are the most expensive and can be bolted on right before dropping the engine in. I still have to put it back to together and fortunately/unfortunately I'll have plenty of time to do it. - Various tune up work on the engine has and is being done to include: various gaskets, hoses and cleaning - Engine is being rebuilt with stock heat coated and balanced pistons, ARP bolts all around, balanced stock rods, JWT cams and valve springs. Should be ready for pick up in a few weeks (how many times have I said that?) - Replacement OEM shift knob remains as yet uninstalled. New floormats have been "installed", thank god. JWT ECU is in the proper place. *Refers to the current laid plans, as more will always be found to do to your car once its "done" Parts list (not including the many, many, many OEM parts I'm replacing as a good measure): Upgrades that were on the car: Z from Japan ECU (small ECU tuner company) ACT clutch Borla cat-back JWT single pop Going into the car: JDM motor - rebuilt top to bottom (everything has been honed, balanced, heat-coated...etc, etc and so on) Specialty Z inconel manifolds Specialty Z split downpipes Custom test pipes JWT ECU JWT Dual pop JWT 400R+ cams JWT valve/VTC springs JWT 530BB turbos (may go another way but 530BBs for now) RPS flywheel Nismo 615cc injectors Nismo Euro spec oil cooler Honed intake plenums Unorthodox UD crank pulley Coming after it's driving: GReddy Profec B Stillen intercoolers Koyo radiator Brembo slotted/cross drilled rotors Brake pad upgrade Steel brake lines 300 Degree MC brace Urethane bushings front to back Sway bars Eibach springs
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
Re: Past Z Car Forum Projects: Remixed
1970 Datsun 240z
Purchased for $125, engine/trans/drivetrain for $175. If I keep it, will modify suspension heavily and use it for track duty.. In process of putting head on block that is in the car, rebuilding carbs, and body work. Car is just a project to learn on.
![]() Soon.. Cars: 1990 Nissan 300zx Twin TurboSold Cars: 1976 Jaguar XJ-S - Rear end Donor to Chev Pickup |
Broke..Sounds like one hell of a car to me...And if you ever sell it I'll have to casterate you.
It's your's for life....or your kids. |
![]() Join Date: Jan 2004
Swapping in VG30DETT into my 2+2... installing all bolt-ons before installation of motor. Hopefully everything is set within a year to this date.
Car: '90 NA Z32 2+2 Project code name: "TT Limo" Goal: At least 450 rwhp... I'd be happy with 400. Drivablity date: I'm driving it now... but I need another car to drive so I can park her Completion date: Good question... A year tops.... hopefully. ($$$) I seriously think it may drag on longer... but I'm trying to stay optimistic. -VG30DETT (already shipping) -Beefed up AT, ie flexplate and torque convertor -honed upper and lower plenum. -BORDER injectors/fuel rail. -JWT cams (???) -AMZ SMIC's or HKS FMIC... debating SMIC or FMIC -AMZ Stage II Turbo's -AMZ DP kit *possible TP kit also (???) -ASHspec ECU -BLITZ Boost Con. -Koyo Rad. (???) -Nitrous (???) -UD pulley -HKS Twin Power Ignition -HKS SSQ BOV's -HKS Hiper Exhaust adapted to fit 2+2
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105 |
*current*
Car: 1986 300zx Project Name: "who knows" Goals: sell this damn thing Status: not looking good on any front *future* Car: 1988 200ZR-II Project Name: "Operation Sex Panther" Goals: low lag 300whp with room to spare Driveability Date: ASAP Completion Date: Unknown Status: On hold, waiting for first project to finish. Future Mod List: ~Full Turbo-back 3" custom mandrel exhaust w/ Tanabe Tuner Medallion muffler ~Custom heat coated intake pipe ~Cone filter w/ custom aluminum heat shield, most likely K&N ~Custom FMIC with 2.5" mandrel bent aluminum tubing ~HKS SSQV bov with optional recirc function ~Aftermarket exhaust manifold ~Aftermarket/custom intake manifold ~greddy profec b boost controller (if i can find the damn thing) and all necessary guages. ~turbo timer, probably cheap ebay one... as long as it works, i'm happy ~some sort of ecu and fuel work, not sure what needs to be done just yet ~all required coolant upgrades (oil cooler, radiator, etc) Future Future plans: ~Shiny new garrett t3/t04 ball bearing turbo ~full engine build -pistons -rods -cams -valvetrain -crank OR rb26dett ![]() lets hope to hell i get a raise or a better paying job in the near future..
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
car: 1986 300zx na
project codename: undecided goal: turboed na car without detruction on first time out driveability date: hopefully before june completion date: also hopefully before june status: waiting for engine to be pulled from donor vehicle and for suspention components mod list: stock turbo ecu and injectors off of 1984 turbo 50th anneversery edition 3" manderal bent exhaust 3"stainless steel air filter 6"x12" oil cooler for prior to turbo water alky inj system ignition coil weight reduction racing seats exhaust wrap instead of heat sheilding hood off 1984 turbo paint kyb shocks edelbrock lowering springs needle bearing type adjustable boost controller bov??? ecu reprogramming from local shop not that its a mod but stock na gears as apposed to the tall turbo gears future mods : aftermarket ignition ..... msd... custom intake (made from exhaust tubing , eliminating water jacket by using seperate crossovers intercooler oversized intake tubing, throttle bodie, and maf ball bearing turbo just all the frills sorta deal |
#7 | |
car 1986 300zxt
project name- dirty hore (i call her that after i try and fit my hands inside and she bites me) project goal- to have a clean car with 350-400 hp while maintaining lowend torque, also i want to pull a 1.0 on the skidpad est date of completion- september, or earlier if the SNAP-ON guy stops being such a freaking tool NAZI status- had car for 4 days... -9" K&N cone, 3" ID/OD exaust coupler to eliminate resonator -3" exaust being bent up as i type -ball and spring boost controller from boostvalve.com ordered yesterday as money comes... - full bushing kit - front and rear swaybars - have subframe connectors machined and welded - full coilover suspension - viscos limited slip - panhard rod fabricated - big brake kit - 17" crome cobra rims - spearco intercooler - turbonetics bb turbo - t56 6speed trans - Ti valvetrain then new paint EDIT: 4.10 rear gears as soon as the 6 speed is bolted up |
#8 | |
![]() Join Date: Jun 2004
dude broke sounds like one hell of a project. good luck with that man.
as for me im in study hall and the period is almost over so ill post my project later |
#9 | |
![]() Join Date: Aug 2004
2 projects.....
1st in no paticular order. car: 1995 300ZX project codename: Gadzooky ( Godzillas child) goal: 300WHP NA driveability date: currently completion date: Winter 2005 status: Currently driving the car, in process of getting front and rear bumbers repainted to fix desert fading. And then getting a electric fan kit and then starting with the whole exhaust system and head work. mod list:Currently just a underdrive pulley. Working on multi-angle port job, porting and polishing, lightened stronger rods, and pistons, a upgraded ignition system, better intake system, complete exhaust system, headers, highflow cats or test pipes depending on where I end up, Borla catback exhaust system. And then getting a new ECU programed to the car. This should get me close to my target numbers. car: Z32 300ZX NA/AT project codename: Super Z goal: A positive displacement Whipple twinscrew supercharged Z32 making 400WHP driveability date: Mid 2006 completion date: Fall 2006 status: Currently on hold till I get settled in again. mod list: To much to list and even try to go into detail here.
Finaly got pics of my car....... after I washed it of course. ![]()
#10 | |
Z Cars Fanatic
Car: 1990 2+2 300zx N/A Automatic
Project Name: ![]() Goal: 550rwhp street machine...with daily drivability and light track duty. Drivability Date: Middle to End of May 2005 Completion Date: A long ways away for the final goal, but not too far away for the TT/5-speed swap with various upgrades. Status: In the proces of swapping a TT/5-speed drivetrain...everything has been ordered to complete the swap except for the driveshaft and radiator. Upgrades On the Car: -Stillen Cat-Back Upgrades going into the Car this year: - Z1 1-piece steel Driveshaft -upgraded oil cooler kit -split downpipes and testpipes -lightened flywheel -solid motormounts -urethane transmission mount -upgraded clutch (already bought) -honed upper and lower plenum -ported exhaust manifolds -koyo radiator w/ new upper mounts -Z1 lower radiator hardpipe kit -Greddy Profec-B -Greddy Turbo Timer -Various Guages -Boost Hardpipe kit w/ Turbo X's RFL BOV's -new wheels and some sticky tires -eibach springs -urethane bushing kit -Carbing strut bars -wings west or stillen side skirts -JDM taillights Upgrades coming Over next winter: (hopefully) -Upgraded Turbos (530BB or HKS???? as of right now) -upgraded Fuel Injectors (Nismo 550cc) -Apollo 3" FMIC -Rebuilt Engine with New upgraded parts that should be about it for the car...as you can see i have alot of stuff to still purchase and install this year. i doubt i will get to all of it but ya never know...
ZedEx Crew Member #4
#11 | |
Sounds good guys! Glad to see we are all finally getting off our asses... ESPECIALLY myself.
#12 | ||
Re: Re: Past Z Car Forum Projects: Remixed
#13 | ||
Re: Re: Re: Past Z Car Forum Projects: Remixed
Did you forget to take your pills, pops?
#14 | |
On Fire!
Since I'm selling the SR240Z, my next project will be 10 times better... better meaning faster. Literally.
Project Name: "Akuma no Z" Chassis: S30 Motor: RB26DETT (Power output to be 500-600hp) Trans: Custom Fit T56 Six Speed Diff: 3.9 or 4.1 R200 LSD: NISMO Competition. Suspension: Full Coil-Over Conversion, Cusco Strut bars, Tokico 5 ways, Sway Bars. Brakes: 13" 6 piston Wilwoods on all Four Corners Wheels: F:16x8 R:16x8.5 RS Watanabe Tires: Yokohama ES100 F:225/50R16 R:245/45R16 < Subject to change. Gauges: Full Autometer Cage: ? Maybe... If I do, Cusco Body/Color: Undecided Spoiler, Front Airdam, Flares, Midnight blue Should cost less than $20,000 to build. Shootng for $15,000 using all my parts hookups. Getting wholesale prices rocks. What she should look like when done...
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#15 | |
GO-FIGHT-KILL!
Damnit... This is making me depressed
![]() -Wes
-2000 PY Acura Integra Type-R #686 - WhoRe -1997 EGP Honda Prelude Type-SH - Daily driver R.I.P Hypsi87:Andy Filson
