Old 04-11-2005, 10:12 PM   #1
niquette
Thumbs down Engine power loss
Chevrolet Lumina APV 1996 : I have experience an intermittent problem.
3 things happen at the same time,. First problem, taking off with the transmission in drive position the engine revolution was unstable than the transmission stayed in first gear and at the same time notice that I lost power from the alternator. I suspect these may be related to a commend use can anyone help.
Thanks,
Niq
niquette is offline   Reply With Quote
Old 04-13-2005, 10:33 PM   #2
k5dan
k5dan's Avatar
Send a message via Yahoo to k5dan
Re: Engine power loss
if the alternator isn't working properly then it could cause your problems especially on a GM product.
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
k5dan is offline   Reply With Quote
Old 04-14-2005, 09:16 PM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Yep. You've got a solenoid activated tranny, they wont shift right (or shift at all) if the voltage is too low. Some will just go to second gear and stay there, if the problem is real bad.
...empty gun rack.
