Code 0446
Having EVAP problems. Getting a code 0446. Kid at AutoZone says it is comming up twice. Same code. I replaced the gas cap twice. Once with cheapy one from AutoZone, second from the dealer. Still have the SES light. Even after a few driving cycles. Then I changed the solenoid valve under the hood. Still no changes after driving cycles. I had read on here about another valve at the rear of the vehicle??? I have a 1997 Blazer 4WD. I checked the hoses and metal lines that run front to back and can't find a leak. Any help would be appreciated.
i have the same problem, dont know what it is,, drives fine
Re: Code 0446
condensation in the system also causes this problem.
1995 Factory Blazer Service Manual for sale, PM if interested. |
ok....pulled neg battery to clear codes. SES light stayed out for a day. The day after it came back on. Any other ideas? If it is condensation how do I get rid of it?? And is there another valve/switch I need to check????
Re: Code 0446
There is usually a solenoid that can be swapped out to repair the problem.
It gets damaged by water getting into the system from not keep ing the tank full at all times.
I replaced the solinoid. That was in my first post
Re: Code 0446
My apologies, sorry about that.
Also, some people have a defective seal in the gas tank cap.
replaced gas cap also. it was also in my first post
Re: Code 0446
Oh god, I'm not havnig a good day.
Forgive me.
the p0446 code says Evaporative Emission Control System Vent Control Circuit Malfunction , were is the vent control circut, is it in that solenoid?? were is that solenid anyway, is it under the hood or by the evap can???
Re: Code 0446
My 2 dr 1996 the solenoid is at the front top of the gas tank just behind the rear axle it looks like this.
http://catservices.wrencheadpro.com/...EM/162-440.jpg |
thanks guys i am going to pull my spare and check it out tonight
Re: Code 0446
Let us know.
Forgot to mention on my other post but my 1996 could have one of two versions the other looks like this http://catservices.wrencheadpro.com/...EM/162-424.jpg
They may be also part of the charcoal canister, my canister is located behind the drivers rear wheel in the bottom of the quarter panel, so if you do not see it by the gas tank look for your charcoal canister. |
