Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 04-22-2005, 03:31 PM   #1
gagipson
s10 2.2 to 4.3 engine swap
I have a 2000 Chevy S10 Xtreme 2.2l 4 cyl. engine. I dont know what I got myself into getting this truck. I was having a problem with tickets with my 2000 Mustang GT, so I had to get out of it. I thought that getting a 4cyl. would keep me out of trouble, it did. Now I want more power before I fall asleep. My wife thinks I should just buy another truck but I think I should just try to swap in the 4.3l V6. I would rather put money into this truck that is already paid off than pay a down payment and get more monthly payments. Well anyway could someone help me with this info, I have looked around but have not found much info. I would like to know how hard the swap is, if it bolts right in, do I need to change the tranny, driveshaft, rear end? Any info would help, I would like to get this done before summer. Thanks
gagipson is offline   Reply With Quote
Old 04-23-2005, 02:39 AM   #2
OverBoardProject
Banned
Re: s10 2.2 to 4.3 engine swap
I don't want to advertise for anyone, but check out advanced adaptors. If you read between the lines you can figure out what you need and find most of the parts in the wrecker
The 4.3L is basicly the same conversion as the v8, including the same transmission
http://www.advanceadapters.com/catalog/037.html
OverBoardProject is offline   Reply With Quote
Old 04-23-2005, 08:23 AM   #3
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
You will need the following
Motor
ECM
Harness
Fuel Pump
Y-Pipe
Transmission (4l60e)
Exaust manifolds (or headers)
All related sensors
Motor mounts
Transmission mount and cross member
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
Old 04-23-2005, 10:34 AM   #4
gagipson
so will the motor mounts on the v6 line up with the 4cyl, or is it going to have to but cut and welded? Thanks for the info
Old 04-23-2005, 12:11 PM   #5
rlith
rlith's Avatar
Re: Re: s10 2.2 to 4.3 engine swap
No the frame mounts just bolt on, as to the engine sides
Old 04-25-2005, 11:02 AM   #6
dtl379
Be sure to check the fuel injection system. If it has the CSPI, i wouldn't bother. The poppet in the injectors are faulty and end up causing more problems than good. If you can find one from California, it should be swapped out to the MFI, but still check the EGR and everything.
dtl379 is offline   Reply With Quote
Old 04-25-2005, 04:29 PM   #7
rlith
rlith's Avatar
For the 96 and up "CSFI" injectors, it's not often they need to be swapped out to the newer style. The upgraded injectors are for replacing problamatic injectors only.
Old 04-25-2005, 05:37 PM   #8
travis712
Send a message via AIM to travis712
Pssh, dump a camaro ls1 or ls2 engine in there, then you can have some fun
travis712 is offline   Reply With Quote
Old 05-05-2005, 09:40 AM   #9
getonmylevel
your better off just putting a V8 in there if your going to put that much time and effort into it.
getonmylevel is offline   Reply With Quote
Old 05-06-2005, 02:26 PM   #10
balls_to_the_wall
balls_to_the_wall's Avatar
I agree with Travis....
Later
-Ryan
balls_to_the_wall is offline   Reply With Quote
