| Exterior and Wheels This is the place for all exterior wheel modifcations. |
C.F. Hood Problems
Well I was excited to install my new vis hood today in MI, it was a nice day for once anyways I swapped hoods and I have 2 problems
1. The heavy duty original spring on the stock latch system is to strong for my C.F. Hood to fully engage so I took it off and it fully engages now however this means I have to push the stock latch back every time before I close the hood anyone ever had this problem? 2. There is a little short of a half inch gap between the fenders and the hood on both sides exposing my green engine bay !!! Has anyone had this problem? I am installin the hood pins on the next warm day I get any suggestions? |
this should be posted in non performace
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
Re: C.F. Hood Problems
is there a way i can move it or should i just start a new thread in non performance, sorry about this |
no dont start a new one pm jake or joewagon and ask them to move it for you
Ummm.......Isn't this the non-performance section? I think you mean problem diagnosis.
95 GSX 14.748 90 GSX |
no a cf hood isnt performance
Re: Re: C.F. Hood Problems
I was in the prob. diagnosis section and was told to be moved to the non performance |
I was not aware the thread had been moved to non-performance already. Ofcourse a cf hood isn't labeled as a performance topic, come on man give me a little more credit than that Also it kinda is a performance upgrade because of the weight reduction, just a thought.
bureaucracy's a bitch. 7 posts, and not one attempt to answer the question.
The latch problem, try getting hood pins if it becomes too much of a hassle, and eliminate the latch all together. OR add a metal hardplate, or another tough compund right where the latch hits the hood. As for green engine bay showing, it could be an alignment problem, or maybe you got a bad hood and the form isnt right. Last edited by Shpyder; 03-17-2005 at 12:58 AM. |
[quote=Shpyder]bureaucracy's a bitch. 7 posts, and not one attempt to answer the question.
Yeah, sorry about that, to bad you have to answer other peoples questions before you can answer the post starters questions Anyway spyder is right the hood might have been formed wrong, where did you get it from? Is the gap on both sides equal or is there a little more gap on one side or the other? If not you maybe can adjust it so the gap doesnt look as big, just a thought. I have heard from alot of people that the stock latch is to strong, maybe you can just take it off if its not holding anything? Definitley get hood pins you dont wont to be going 65 down the highway and your hood fly open and slap your windshield and cause you to wreck!!
I agree with the hood pins idea. They're tough as nails, hold your hood shut without issue, and look cool as hell too
Ok well that is a good idea why not just eliminate the stock latch in the center and use hood pins, I have the hood pins but it is to cold outside to install and I am installing them the next warm day I get, but heres the main issue. The rubber stopers under the hood had to be screwed down more in order for the stock latch to fully engage, this means that the fenders are higher than the lower part of the hood... Ugly in appearance, so are you guys saying I should just install the hood pins and totaly eliminate the center latch locking system? Also the latch spring was heavy duty and had to be removed in order for the hood to lock into place...
As for the gaps the one side is bigger than the other and they are both around a quarter of an inch... |
eliminate the stock latch put hood pins on thats why they are made the way they are is becuase CF hoods are so light they get caught by air and fly right up. get hood pins, eliminate the latch.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black) Stock 93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red) Cosmo Racing Air Filter Brembo Rotors 14b turbo Faze Boost Gauge Faze Air/Fuel Gauge Dual Gauge Pod Megan Racing 3" turbo back exhaust 450cc Injectors I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested |
I wouldnt suggest eliminating the latch, but try and bring to somewhere see if they can fix it. If you have no latch and just hood pins, ppl can break the hood pins and open your hood no problem, then with the right tools, theyll be parting out your car, just my two cents
I agree with smicaa72... you know how young jealous punks can be!!! Is there a way to extend the latch so you don't have to put the hood down so far? or is it formed right into the hood? I've never seen the underside so..... If it wasn't formed into the underside maybe "shim" it with washers or something of the like...or possible have them cut and lengthened...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
