Register FAQ Social Groups
Old 03-27-2002, 03:16 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Code number 41.
I guess this is a common problem with VTEC Engines when you put mods on the car. I just started to get Code 41. I found a place where I am going to get a new o2 Sensor for like 45 bucks. If anyone else gets this problem let me know. By the way Code 41 is o2 Sensor Heated. I burnt out my o2 sensor after I did this Fat burn out few days ago.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 03-27-2002, 08:10 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
what mode did you do that will burnt out the O2 sensor? I highly doubt the mode that you have currnetly will do that. You should make sure the problem is coming from the sensor before buying another sensor (ex. may be wire is loose, a faulty wire)
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
