Old 02-19-2005, 01:13 AM
57ringo 57ringo is offline
95 ignition switch replacement help
How much of a job is it to change the ignition switch on my 95 K2500? Do you need any special tools?
Old 02-19-2005, 02:40 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 95 ignition switch replacement help
I'd recommend buying a repair manual. Makes the job much easier, and there's pictures to look at. Replacing the ignition switch on my 86 was pretty easy. Just had to take off the cover under the steering column, remove the bolts holding the steering column up, and take two other electrical things off. Took about an hour.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
