Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 02-11-2005, 02:40 PM   #1
diy-dad
Any tips on finding a possible vacuum leak?
I have an 89 Astro CL, and have already found two vacuum problems. Is there an easier way to find the leaks than inspecting every square inch of vacuum line as it is a tight space to get into. The two leaks I found were the T-connector on the left side of the engine beside the ac system, and the line that joins the purge canister to the intake manifold.
The older I get the younger I was.
diy-dad is offline   Reply With Quote
Old 02-13-2005, 06:04 PM   #2
Kings-x59
Re: Any tips on finding a possible vacuum leak?
I've got an '89 as well. Congrats that it still runs.
A vaccum test pump runs about 20 bucks or so.
Ironic that the weakest link in all the engine systems is biggest pain in the a** to diagnose.
Kings-x59 is offline   Reply With Quote
Old 02-14-2005, 09:22 PM   #3
J-Ri
J-Ri's Avatar
Just replace all of them. If some are starting to leak, the others probably aren't far behind.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
