Go Back   Automotive Forums .com Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-14-2005, 10:21 PM   #1
Explorer94
Temp gage dont work in 94
even on hot days or cold days the temp gage won't move it just stays on cold. what should i do? replace the thermastat? where is that located in a 94 explorer?
Thanks.
Explorer94 is offline   Reply With Quote
Old 01-15-2005, 08:54 PM   #2
sabre
Early explorers suffered from from two problems that led to cold-running engines and/or cold reading temp gauges. The thermostats can open too much and never allow the coolant to get hot, or the temp gauge sender can fail and it will show up as a cold engine on your temp gauge even though the actual coolant temp is hot. Do the thermostat first, that usually gets the temp gauge needle closer to the middle of the gauge, if it doesn't then replace the sender( it's a single wire brass thingy that's at the front end of the intake manifold). The thermostat is also located on the front of the intake manifold.
sabre is offline   Reply With Quote
Old 02-04-2005, 01:03 PM   #3
n0c7
Re: Temp gage dont work in 94
Do you have a picture of the temp gauge sender?
n0c7 is offline   Reply With Quote
Old 02-04-2005, 03:57 PM   #4
B33p3r
You said it's not reading hot. But is the engine actually getting hot? Do you have good heat?
B33p3r is offline   Reply With Quote
Old 02-07-2005, 01:25 PM   #5
n0c7
Mine does that, says its not reading hot but it gets hot, even in the coldest weather. Tonnes of heat. I've changed the thermostat and the temp gauge sender, and it still doesnt read properly.
