Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 02-03-2005, 04:09 PM   #1
Scott Stephens
#4 misfireing
I have a 99 trooper 3.5l. I am having roughe idle situation with a check engine lite on. Sofar I used a code reader and the code was 0304 which my book says is #4 missfire. So I checked the plugs and replaced them I also swapped the # 4 and th#2 coil pack around still the same code. Then I pulled the #4 coil installed a plug to group and started the engine good spark? So where do I go from here? I am wondering is missfire mean dirty injector? but I do smell extra gas.
Scott Stephens is offline   Reply With Quote
Old 02-03-2005, 04:43 PM   #2
travelman
I don't remember my code number but I had a misfire on cylinder #4 of my 99. I did the coil swap, check the spark and got nowhere. My cure was to gently tap the fuel rail by the #4 injector. I used the handle of my screwdriver for the tap and the engine was running. This instantly cured the problem and about a year later no recurrence. I have since used a bottle of Techron every 3 or 4 months. I was already changing the fuel filter every 24kmis or so.
My theory was that a tiny bit of something fouled the injector. The gently tap was just enough to break it up. No guarantee but unless you hit the rail too hard (or the much more fragile injector rather than the rail) what have you got to lose?
travelman is offline   Reply With Quote
Old 02-03-2005, 10:19 PM   #3
amigo-2k
Isuzu Guy
Re: #4 misfireing
what brand of plugs did you use?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 02-03-2005, 10:59 PM   #4
Scott Stephens
Re: #4 misfireing
I bought a set of ac plugs double plat oe replacment the plugs that came out were chapion double platnium.
