Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 05-31-2004, 06:28 PM
jasonguidry jasonguidry is offline
Send a message via Yahoo to jasonguidry
1997 Skylark with coolant leak
Hello all,
Hopefully someone can help me with this.
I just bought a second hand 1997 Buick Skylark Custom with 2.4L 4-cyl. engine. It Has just over 58000 on it now. About a week after purchasing it, I noticed a coolant leak. Fluid is leaking and finding its final destination about 12 inches inside the front passenger wheel. I've searched for a source to the leak, but have been unable to locate it beyond saying it is somewhere under the engine where I can't see it (at least not without putting it on a lift). I check the fluid level when the engine is cold, it is actually a bit high still. So, here is my question. Is the high coolant level the cause of the leak? Is the excess coolant being release somewhere when the pressure gets to high? Should I be in a panic about an expensive repair on a car I just bought (ha,ah)?
Any help would be greatly appreciated.
TIA,
Jason
Old 05-31-2004, 07:05 PM
ghostguy6's Avatar
ghostguy6 ghostguy6 is offline
Send a message via AIM to ghostguy6 Send a message via MSN to ghostguy6 Send a message via Yahoo to ghostguy6
Re: 1997 Skylark with coolant leak
it may be to much coolant in the resaivour but it may also be a leak from the water pump.
Want to be a mod? Join up at www.mypicgallery.com and PM me.
Old 05-31-2004, 07:56 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I'm not well versed in the 2.4 liter engine, but look for a bypass hose under the alternator.
Old 05-31-2004, 09:09 PM
One other thing I should have mentioned. Before I bought it, I noticed the belt was worn out, so they replaced it for me. Could something have happened when they replaced to belt to have caused this behavior?
Old 06-17-2004, 09:00 PM
Problem Fixed
Turns out it was the water pump. It had a slow leak that would only start after driving for about 15 or 20 minutes.
Old 08-13-2004, 11:51 AM
akinkanju akinkanju is offline
Greetings,
This morning after coming into work, I noticed the familiar smell of coolant leaking from my car. After parking I check under my car and literally watched the coolant leak from my 97 buick skylark in a water faucet like fashion. Needless to say my car is not with out coolant. It is an external leak. Does anyone know if there is a way I can fix the leak or is there any kind of bandaid I can give it until i can get it into a shop. Please help.
-Ak
Old 08-13-2004, 04:42 PM
tman's Avatar
Pimpin' ain't easy
Tell us WHERE specifically its leaking from, and we'll help you.
Old 02-05-2005, 04:29 PM
ps27 ps27 is offline
I had the same type of problem with the antifreeze leaking out of my 96 2.4l it was leaking through the t-stat housing. The t-stat went bad and blew the gasket out of place. It is now fixed.
