Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-09-2005, 01:02 PM   #1
beach_bar
Unhappy Strange problem with my 95 neon
I have a 95 neon sport, 5 speed, 150,000 miles, original fuel pump. If I go down a steep hill and use the engine to break, when it gets to between 3000 and 3500 rpm the battery light comes on and I can feel the engine cut out. If I shift to a higher gear the problem goes away. Also, if I am accelerating hard, when I shift and take my foot off the gas while the clutch is in the battery light flashes on and I can feel the engine miss. I have replaced the negative battery cable and the positive terminal. Could this be the throttle position sensor? Any help/ideas would be greatly appreciated. It has been doing this for about 2 months and is getting progressively worse.
Thanks,
Craig
beach_bar is offline   Reply With Quote
Old 01-09-2005, 03:28 PM   #2
skatendestroy
Send a message via AIM to skatendestroy
Re: Strange problem with my 95 neon
Your alternator is going bad. that is the problem.
skatendestroy is offline   Reply With Quote
Old 01-09-2005, 10:39 PM   #3
beach_bar
Re: Re: Strange problem with my 95 neon
Thank you - thank you. I'll replace it report back. It is original.
Old 01-18-2005, 01:12 PM   #4
beach_bar
Raplaced the alternator and all in now fine. Thanks again
