Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 12-05-2004, 10:14 PM   #1
96cavi
Send a message via AIM to 96cavi
fuel pump relay
does anyone know how to swap fuel pump relays?? how hard is it and how would i go about doing it.. thanks
96cavi is offline   Reply With Quote
Old 12-05-2004, 11:26 PM   #2
OverBoardProject
Banned
Re: fuel pump relay
just like a plug, I believe under the hood on most chevy's although your owners manual will tell you for sure.
those relays just burn out like a light bulb, so if your having a problem it's probably wiring, or the fuel pump it's self
OverBoardProject is offline   Reply With Quote
Old 12-06-2004, 05:12 PM   #3
Fractured1
I know on my 96 it's in the glove box...
Fractured1 is offline   Reply With Quote
Old 12-07-2004, 10:33 PM   #4
96cavi
Re: fuel pump relay
does anyone know where the fuel pump relay is in an 88 s10?
thanks
Old 12-11-2004, 09:13 PM   #5
general poot
Re: Re: fuel pump relay
thanks
I beleive it is on top of the drivers side wheel well. It is a small black square box with a plug in harness. There is probably two relays beside each other, it will be the rear one. Good Luck!
general poot is offline   Reply With Quote
Old 12-11-2004, 10:13 PM   #6
jackass#1
jackass#1's Avatar
Send a message via Yahoo to jackass#1
Re: fuel pump relay
drivers side on firewall right behind or just to the right of mastercylinder
jackass#1 is offline   Reply With Quote
Old 12-12-2004, 03:41 PM   #7
xtremetrk
Re: fuel pump relay
Ya its as easy as switching out a fuse. It's in the fuse box under the hood. on my 99 s-10 it's on the drivers side but on an 88 the fuse box under the hood could be somewhere else.
xtremetrk is offline   Reply With Quote
