Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-12-2004, 05:03 PM   #1
tyko909
Send a message via Yahoo to tyko909
ticking in dash
I am stumped on what it is that sounds like a clock ticking in my dash. I have a 95 talon tsi awd. Comes from up by the gauge cluster.
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
tyko909 is offline   Reply With Quote
Old 12-12-2004, 05:30 PM   #2
97_3clipse
97_3clipse's Avatar
Send a message via AIM to 97_3clipse
Re: ticking in dash
might be a relay...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
97_3clipse is offline   Reply With Quote
Old 12-12-2004, 05:32 PM   #3
97_3clipse
97_3clipse's Avatar
Re: ticking in dash
it would also be nice tyko909 , if oyu could scale down your signature...that thing is huge!
Old 12-12-2004, 08:33 PM   #4
joemathews
joemathews's Avatar
Re: ticking in dash
Put your car model, year, drivetrain, and tranny in your sig!
Is the tick rpm-related? Does it get faster or slower when you open up the throttle? If not, it is probably electrical.
Might be lifter tick, which generally sounds like it's coming from the dash area...
1996 Eagle Talon
joemathews is offline   Reply With Quote
Old 12-13-2004, 12:02 AM   #5
tyko909
its not from outside the car. It literaly sounds like a loud clock ticking. My friend was joking around and said that it sounded like there was a bomb in the dash.
Old 12-15-2004, 09:25 PM   #6
TreeFrog
TreeFrog's Avatar
Send a message via AIM to TreeFrog
mine does it when the rear winshield wiper turns on. stupid but it doese sound like a clicking clock from the dash
Something new is coming...
TreeFrog is offline   Reply With Quote
Old 12-16-2004, 12:36 AM   #7
beatdown944
dsm.org
I have the same noise coming from a 95 gsx. On dsm.org there are discussions about this being related to a faulty part in the ecu that causes a melltdown. there are manuals on how to diagnose and repair. I have this noise pop up between 1k to 1500 rpm in first gear. goes away after that.
beatdown944 is offline   Reply With Quote
