I am installing a new set of heads to my 350. I have all the new gaskets for the install but am not sure about the proper instalation method.Are there some tricks that would help in the install. What steps should I do to make sure the job is done right the first time. Thanks for any input!!!
Re: 350 Head Installation
Always make sure the block surface is clean and the heads are clean. I use a non hardening sealant and torque to 60-70 ft.lbs.
use proper torquing process though. dont just tighten the head bolts down to 70 ftlbs. When torquing bolts you need to go in steps like: 25ftlbs to all the bolts(in proper sequence), 50ftlbs, then 75 ftlbs. You can warp the heads if you dont do this.
1973 Camaro AFR 195cc heads CNC Motorsports 383 short block Comp Cams hyd flat tappet TH350 Dual 3" exhaust (LOUD) Corporate 10 bolt w/ all new internals and axles |
