Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 11-28-2004, 08:49 AM   #1
Rowdysrides
Power steering pressure switch
Well I should have known, after all the work we did to our 96 3.8 this year (water pump, tie rod, head gasket replacement, etc) it comes up with a NEW problem yesterday. Whenever we would pull into a parking spot it would stall....only on a full complete turn. So did some research on Alldata and it seems it may be the 'Power Steering Pressure Switch', anyone been 'lucky' enough to have to change one of those?? I know it's located on the rack.
Any suggestions or helpful tips would be appreciated.
Thanks
Rowdysrides is offline   Reply With Quote
Old 11-29-2004, 12:09 AM   #2
windstar4family
If my memory serves me correctly the ps pressure switch is on the left side of the steering rack, just below the brake booster/master cylinder. It is located on one of the ps lines going into the rack. You can see it through the drivers fender well if you take the lf tire off and peer through past the inner fenderwell. Hope this helps.
windstar4family is offline   Reply With Quote
