Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-04-2002, 02:24 AM
Mad Sentra Mad Sentra is offline
Send a message via ICQ to Mad Sentra Send a message via AIM to Mad Sentra Send a message via Yahoo to Mad Sentra
For the pro's. Engine swap for 83 TE-71
I've got a 83 Liftback RWD still. This car is about to be sold unless I can think of something to do with it.
I've decided to make it into a project car but the first thing is the engine... 150K+ miles won't do... I need a new engine and something powerful.
Tell me what engines will fit. I know that a 4A-GE and even 20vvt or 4A-GZE will fit... I want the most power possible...
Old 07-27-2002, 03:30 AM
TOYCOOLROLLA TOYCOOLROLLA is offline
Send a message via AIM to TOYCOOLROLLA Send a message via Yahoo to TOYCOOLROLLA
Cool TE7X
MAD SENTRA,
GO USE A 3SGTE FOR MORE POWER AS THIS IS ALSO WHAT I USE ON MY CAR AND IT DRIVES LIKE NUTS. ITS VERY TORQUEY AND HAS HI-HP.
Old 10-01-2002, 05:07 AM
RollaCoupe RollaCoupe is offline
If your Te71 has a 2T-c or 3T-c it should be fairly simple to fit one of these engines.
2T-G 1.6 Dohc /w factory twin carbs. these are fairly equal in performance to a stock 16v 4ag.
2T-GE as above but with EFI
3T-GTE 1.8 Dohc turbo if you can find it this would be lots of fun but more expensive to maintain as it uses some unique parts. buy some spare gearboxes and try to find an Ma40 series supra axle as these have LSD and disc brakes.
2T-G can make 200hp very cheaply, especially if stroked using a 3T crank.
3T-GTE are probably the strongest old-school toyota 4cyl good for 300hp with just bolted-on bits and tweaking. 4-500hp is no problem once fitted with aftermarket rods, pistons, a larger turbo and aftermarket management.
