Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 10-28-2004, 01:08 PM   #1
nfgguitardude
Send a message via AIM to nfgguitardude
How do I remove the center console to change out the cd player????
I know this sounds like a dumb question... but I just bought a 1990 eclipse and I dont wanna screw it up. It has the radio and tape deck in the console.. and I want to remove the tape deck to put a cd player in... but how do I remove it? I don't wanna just start pulling things apart and break something. So if someone could give me some help I would GREATLY appreciate it. Thanks guys!
nfgguitardude is offline   Reply With Quote
Old 10-28-2004, 09:11 PM   #2
1stGenRocks
1stGenRocks's Avatar
Send a message via AIM to 1stGenRocks
Re: How do I remove the center console to change out the cd player????
the trim ring around the stereo will pop out if you gently pry it loose around the edges. then its just four screws that hold the radio brackets in place. take them out and pull the whole stereo assembley out bolt your new one to the brackets and get a wiring harness adaptor. i wont tell you the color codes cuz i dont know them and i hate when people hack it together instead of buying the 2 dollar connector. itas much easier to do anything with if you can just unplug it when you want to take it out.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
1stGenRocks is offline   Reply With Quote
Old 11-12-2004, 04:12 PM   #3
macder
Send a message via MSN to macder
check out www.installdr.com for color codes
macder is offline   Reply With Quote
Old 11-12-2004, 08:17 PM   #4
RSLaser
Use the manual for the wire colors from the car, and use the instruction book you SHOULD have for the stereo for the rest. It may have been rewired(also check for little flags on the wires.
1991 Plymouth Laser RS
Only sat for a few years....
RSLaser is offline   Reply With Quote
Old 11-17-2004, 08:05 PM   #5
xavier3jr
xavier3jr's Avatar
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
pop off the little thing around the ac controls theres 2 screws there take out ur cup holder and ash trey theres 2 under there move ur seats all there way up and theres 1 on each side take off ur shifter knob and lift up
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
xavier3jr is offline   Reply With Quote
Old 11-17-2004, 08:22 PM   #6
97_3clipse
97_3clipse's Avatar
Send a message via AIM to 97_3clipse
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
97_3clipse is offline   Reply With Quote
Old 11-17-2004, 08:22 PM   #7
97_3clipse
97_3clipse's Avatar
opps thats for a 2G
Old 11-18-2004, 11:06 PM   #8
xavier3jr
xavier3jr's Avatar
oh my bad wut i said was for a 2g to sorry
