| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
white smoke coming out the exhaust and oil pressure reading low
white smoke coming out the exhaust and oil pressure reading low and when i give it gas the smoke gets alot heavier then the oil pressure goes up high sombody please help
Re: white smoke coming out the exhaust and oil pressure reading low
How is the turbo shaft play (radially and thrust)?
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Re: white smoke coming out the exhaust and oil pressure reading low
Remove the intake pipe so you can see the compressor wheel. Grab that bastard (make sure its not too hot) and wiggle around. Push it in an out. There will be some small amount of noticeable play. But it should be small. If its excessive (more than 1/16th of an inch for example), you could be pushing oil by the turbo oil seals. When you get a LOT of smoke its almost always the turbo. Valve seals can burn a quart a week and not smoke, in my experience.
Re: Re: Re: white smoke coming out the exhaust and oil pressure reading low
I would have been hoping it was the turbo, the other causes are harder to fix for the average DSMer. Which of the other two causes it is, anyones guess. Try a leakdown test and see if that leads to anything. Since you need to pull the head to do either one, you might as well fix both things. Get the head inspected and rebuilt, and you obviously have no choice but to use a new gasket. If it still smokes after that, good luck to you.
over here they charge 600+ for a headgasket change.
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
