Need New Motor
Hey everyone, I have an 89 Integra D16A1 m/t. I am trying to find a B16A1 for a swap and i'm trying to spend as little money as possible. If anyone knows where I can get a cheap B16A1 from any help would be greatly appreciated. If not a B16A1 a D16A1. Thanx again.
TJ |
Re: Need New Motor
Cant help you there, but I'm selling a B18C1 for $1,500. I live in S.C. if your interested.
![]() Im not proud of my car because its fast, Im proud of it be cause I built it that way. |
There is no Spoon
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002
Re: Need New Motor
https://passwordjdm.com/index.php?pa...id=engineswaps
$1399, cheapest full swap I've seen around. |
Re: Need New Motor
Rating, wat condition is ur B18C1 in? How many miles are on it? And are you selling just the engine or the whole package? The last thing I have to ask is would it bolt up with my car or would I have to make it fit, do you know? Thanks for the info. Also thanx civicspoon for the site.
Re: Need New Motor
The B18C1 is in excellent running condition. Has around 110k miles. Its just the motor im selling, no tranny, no ecu, no mounts. If your trying to find a b16a motor to swap in, you would have to do the same process with the B18C1.
What I am selling is a B18C1 Motor for $1,500. Items included for free are: I do have reciepts of purchase if needed. These are not pre installed. Brand New Poly and Aluminum Motor Mounts $200 Value OBX Cam Gears $100 Value These were removed during the motor pulling process. ACT Stage 2 Turbo Clutch $460 Value OEM Intake Manafold OEM Flywheel OEM Header OEM Oil Pan OEM Distributor OEM Spark Plug Wires OEM Spark Plug Cover And anything extra I can find laying around here for that motor.
![]() Im not proud of my car because its fast, Im proud of it be cause I built it that way. Last edited by Rating; 09-10-2004 at 05:08 AM. |
Re: Need New Motor
Get a use LS motor and 5-Speed trans. Swap in a light flywheel, and race clutch. Drop the engine in. Install a cylinder brace, block girdle and quality head gasket. Then slap on a Drag turbo kit and be done with it.
Should the LS engine go, you can pick another up cheap and swap the turbo on it.
~ Steve 00 Eclipse GT - 00 Montero XLS 4x4 - 96 Integra LS 99 Kawasaki ZRX 1100 - 81 Suzuki 450 cafe' racer - 75 Kawasaki KX 250 - 74 Suzuki YZ 125 69 Ford Galaxie XL Conv. - 69 Ford LTD 2-door Formal Top - 67 Ford Galaxie 500 Conv. |
