Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 06-06-2004, 04:14 PM   #1
nm325e
temp gauge needle jumps
During normal driving. Needle on temp gauge "swings" from mid to over heat. after about 1/2 of normal driving the gauge stabilizes a little over mid. don't know if its the thermostat or what.
nm325e is offline   Reply With Quote
Old 06-07-2004, 09:38 PM   #2
jeffreyb4me
Re: temp gauge needle jumps
first be sure t-stat & fan clutch are GOOD and the system is full and bled [no air]....]is it really running hot or is it a cluster problem]....check the engine first.........then if the gauge still 'bounces' around the most common fault is a loose/missing gauge nut on the back of the cluster.
jeffreyb4me is offline   Reply With Quote
Old 07-21-2004, 11:12 AM   #3
nm325e
thanks i'm thinking its a cluster issue now. once i tap on the gauge it seems to go to the mid point.
