Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 06-28-2004, 02:47 AM
93_LX's Avatar
93_LX 93_LX is offline
Which Gear ?
I run a 1993 GLX 2.3l dual port fi at my local 1/2 mile asphalt circle track, it is a stock class no mods allowed. My problem is in the turns if I shift to 2nd gear when I get into a turn my rev limiter kicks in, if I stay in 3rd I lose my RPMs and get a crappy exit. I would like some suggestions on what ring and pinion I should be using. Thanks
Old 06-28-2004, 04:39 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
ring and pinion doesn't count as a mod? interesting. well, if you go up in ratio (bigger number), you will turn more rpms in 2nd gear, which should give you a cleaner exit. you'll lose a little top speed tho.
somebody correct me if i'm wrong, it's almost 5 in the morning and i can't sleep
edit: having reread the origional post, i realize i'm an idiot.
yet i should still be right cuz you'd still turn higher rpms in 3rd, solving the problem.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 06-28-2004, 10:09 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Which Gear ?
Have you thought about having a custom chip burned to remove the rev-limiter?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 06-28-2004, 10:56 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Which Gear ?
you said its a stock class no mods so what can you do first we can work from there.
Old 06-28-2004, 11:21 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Which Gear ?
Good point, I missed that stock class part the first time.
-2013 Ford Flex
-1999 Ford F150
Old 06-28-2004, 04:11 PM
93_LX's Avatar
No motor work allowed. I removed my smog, heater core, and installed a K&N filter, 4 gallon fuel cell and an MSD fuel pump. My tires are 185/70/14. We must run a 70 series tire and the wheel has to be stock for the year, make and model.
My diff cover tag : 8 45 75 3f18
: S2900
Old 06-28-2004, 04:50 PM
if i'm reading that right you have a 3.18 gear... maybe step up to a 3.53?
-Andy
Old 06-28-2004, 07:05 PM
93_LX's Avatar
Re: Which Gear ?
Thanks for the input StangNut86 it is appreciated.
Old 07-21-2004, 01:34 AM
96scort 96scort is offline
Re: Which Gear ?
id go with 4 tens i drove a 90 with everything stock but fourten gears and it grabed me by the nuts
