| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
Whats up guys, I have a question that i would like you to answer realistically, I might be buying 19inch 215/35 rims for my 99 Si civic.
I know that itll be slower than any car on the road, unsprung weight, affects everything, ride will not be comfortable and lots of negatives. BUT is it doable?? DO i need modifications? Will it RUB? Is there a way to solve the rubbing, such a modification? For reasons other than practicality, performance, confort (which are the most important) I want to do put these rims on my car. Can you help me out? Thanks a lot. MexSIR.
Honda Civic 1999 EBP SiR Im not as fast as I am furious. 1/4 mile = 15.347 (sealevel) Porsche RS America BMW 323 01 Pictures of my ride (Pictures)
![]() Join Date: Sep 2005
Re: 19" Inch RIMS (Need Help)
As you already know all the negatives...
Commonly 19 inch rims are wider than the conventional 15 inch that came on your car, even wider than a 17 inch wheel. Try to found those rims 8 inch (wide) or less. In my experience a friend drive a 96 integra with 19 inch rims and lowered (cut the factory springs), it looks great but rub the tires on the fenders. Anotherone drive a 01 civic with 18 inch rims and 215/35 (or 40), lowered (with aftermarket springs) and no any problems. I recommend to you inspect, and replace if necesary: *all the suspension bushings in the front end and rear *"boots" *shocks *springs, if you want a lower ride I recommend H&R sport (1.75 front, 1.5 rear) springs, beacause are one of the bests springs on the market and have low lowring rate If you plann to lwer the vehicle install a camber correction kit (most if you will use 17+ inch rims). Just inspect the suspension components and drive easyly and you should not have problems. [Maybe the tire rub when entire steering the vehicle.] |
