Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 03-25-2006, 04:27 PM   #1
Chango
3.3 voyager 1993 tension pulley squealling!
I just replaced this same pulley three months ago! My wife was just driving and the whole pulley just snapped off! The replacement was hell getting into place (could not reach the bolt!) So now the same pulley is squealing really bad again as if it's going to let go again. I'm really worried as this is our only form of transportation at the moment. Is this a common problem? and is there any easier way to reach that bolt if I need to replace it again? Any help would be greatly apprecieated! Thanks in advance.
Chango is offline   Reply With Quote
Old 03-25-2006, 07:04 PM   #2
KManiac
KManiac's Avatar
Re: 3.3 voyager 1993 tension pulley squealling!
When you say you replaced the tensioner pulley, did you replace the entire tensioner assembly (tensioner and pulley together) or just the pulley and bearing?
The pulley can be replaced separate from the tensioner itself. I replaced the both the tensioner pulley and idler pulley on my 1998 T&C with 3.8 last summer. The pulleys were identical and I bought two new pulley kits for $17 each. To replace, I merely removed the belt and unscrewed the center axle bolt for each pulley. A five minute job. What bolt are you having trouble with?
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
KManiac is offline   Reply With Quote
Old 03-26-2006, 03:06 AM   #3
Chango
it was actually the tension arm and pulley! I found that I could not get to one of the bolts with out having my son actully climb under the van an reach in from behind the motor. I was thinking there has to be a easier way. But if I can locate just the pulley and I can change it I will do that A.S.A.P! I will let you know Thanks for your reply!
