Go Back   Automotive Forums .com Car Chat > Pontiac > Montana/Montana SV6
Old 02-07-2003, 11:54 PM   #1
rubberman
99 Montana keyless remote re-programming..
Anyone know the reprogramming instructions for a 99 Pontiac Montana? thanks
rubberman is offline   Reply With Quote
Old 02-08-2003, 12:43 AM   #2
Jimster
Here for the pussy, man.
Jimster's Avatar
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
Might I suggest the Pontiac forum?
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Jimster is offline   Reply With Quote
Old 02-10-2003, 01:40 PM   #3
Shortbus
Blah blah blah
Send a message via AIM to Shortbus
I will move this to the pontiac forum and leave the redirect here in Chevy. Thanks John
1999 Pontiac Base Montana
If you have the Montana EXT see the second post
Transmitter Programming
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important
Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
Remove the ignition key from the ignition lock cylinder.
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
© Copyright General Motors Corporation. All Rights Reserved.
Shortbus is offline   Reply With Quote
Old 02-10-2003, 01:41 PM   #4
Shortbus
Blah blah blah
Document ID # 339804
1999 Pontiac Montana Ext.
Important
Close the liftgate.
Important
Old 02-10-2003, 01:43 PM   #5
Shortbus
Blah blah blah
Man I am really postwhoring today.
I think those are the same procedures. I just wanted to cover the bases they had a manual for both ext and base Montana's.
I did'nt have time to compare them.
Old 02-10-2003, 07:07 PM   #6
rubberman
A little confused on the procedure below.
"After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming."
When do i press and hold the LOCK and UNLOCK buttons on the remotes? Do i wait after the 2nd chime or right after the 1st chime? doesnt make sense.
Old 02-10-2003, 07:22 PM   #7
Shortbus
Blah blah blah
After the chime sounds when you close the door that is when you hold the button for 14 seconds. It is just telling you that you may hear the synch chime at 7 seconds while holding the buttons. Do not let go here. Just wait until the second chime approx 14 seconds.
Old 02-10-2003, 10:18 PM   #8
Scott 02
Banned
Scott 02's Avatar
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
Thanks for posting that John. Seems that everyone asks about this. For now on im going to tell them to come here and look Or have them talk to you about it b/c im not the man with the reference books right in front of me... :finger:
Scott 02 is offline   Reply With Quote
Old 02-10-2003, 10:21 PM   #9
Shortbus
Blah blah blah
Yeah seems like keyless entry questions make up most of the active content on the GM Forums. Oh well we are happy to have them, and happier to be able to help.
Old 02-10-2003, 10:24 PM   #10
Scott 02
Banned
Scott 02's Avatar
Yes, thanks for helping them out John. I wish i could but i don't have that much experience with keyless entrys at all. If I ever need a price on a GM Part of have this keyless entry frustration...You'll be the first I get a hold of.
Old 02-11-2003, 08:02 AM   #11
rubberman
Thanks John, much clearer now. Seems that GM makes the programming of keyless entry top secret. I bought this van 2 weeks ago and the dealer didnt have the remotes until this past week. When i brought the van so they could program the remotes they took off in the van to the end of the garage to program them. Its like they do want anyone to know how they do this. Then the dipsh!t tried programming my Blazer remote. He said i cant program this one cause its for a truck/blazer/jimmy vehicle. No kidding! So when i got home i had to reprogram the Blazer remotes which is easy to do. Anyway thanks again!
Old 02-11-2003, 09:43 AM   #12
Shortbus
Blah blah blah
Glad to have been able to help. Enjoy your Montana
Old 03-06-2003, 09:19 AM   #13
comntnbkr
Question 99 Montana keyless remote programming
Greetings,
Can anyone tell me if I use the programming instructions for programming a 99 Montana...will it activate the side door opening button on my remote???
John
comntnbkr is offline   Reply With Quote
Old 03-06-2003, 09:28 AM   #14
Shortbus
Blah blah blah
It should work if the remotes work.
Here is an excert from the manual.
Power Sliding Door
If the vehicle is equipped with a power sliding door (E58), the transmitter will have a power sliding door button. Press the power sliding door button in order to open the power sliding door. To close the power sliding door, press the power sliding door button again.
If the sliding door is locked, perform the following steps:
Unlock all of the vehicle doors.
Refer to Driver Door and All Door Unlock.
Press the power sliding door button again in order to close the power sliding door.
You can operate the power sliding door with the transmitter only when the power sliding door override switch on the overhead console is off.
I hope this helps you out.
Welcome to AF
John
Old 03-28-2003, 06:42 AM   #15
missadavis
do the 99 instructions also apply for a 98?
I have a 1998 Pontiac Transport. Will the 1999 Montana instructions also work to program my remote? The dealer want $45 to do it!
missadavis is offline   Reply With Quote
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 09:13 AM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-17-2010 12:17 AM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 01:28 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 07:37 PM
1997 Buick Lesabre keyless remote re-program squashplayer General Discussion 0 07-23-2004 08:24 PM
