Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-29-2004, 08:58 PM
biker1mike biker1mike is offline
Send a message via Yahoo to biker1mike
97 Starter How To?
97 SOHC / AC / Automatic / High Light Made in Mexico
I need to replace my kid's Neon's starter. What do I need to remove to get to the studs? Thanks for any help. It has been many years since I had to lay on the driveway under a car.
Old 05-30-2004, 12:30 AM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
Re: 97 Starter How To?
A Haynes repair manual is an awesome thing to have. They give pretty clear step by step instructions, most of the time with illustrations.
Acting my age is no fun.....
Old 05-31-2004, 11:21 AM
Thank you,
Got the Haynes manual. Put the car on stands and took a look. " Remove front motor mount and rotate engine........" Looked a little further on what I would be up against and dropped the car back off the stands. Odds are I this job is more than what I and my tools can do. I'll call my mechanic.
Mike
Old 05-31-2004, 09:08 PM
9neon5 9neon5 is offline
I suggest you take it to a mechanic. Because my dad has a shop with a lift and it still took us a while to change the starter on my 95 neon.
You have to remove the battery, battery box. Unbolt engine mounts rotate engine. It is a pain. Dont do it in the driveway.
Check out the N3ON
http://www.cardomain.com/id/9neon5
Old 06-03-2004, 12:12 AM
Yea, unfortunatly alot of the stuff with these cars are a pain in the ass. That's what we get for having a small car with not much space in the engine compartment for anything. They just had to kinda shove everything in there any way it would fit....... Gotta love it.
Old 06-16-2004, 09:50 PM
xxJosiahxx xxJosiahxx is offline
hmmmm
for a non magnum neon its not difficult at all to swap starters. pretty much nothing more than taking out battery and tray removing two bolts and disconnecting the starter wires (make sure you rewire it correctly..could end up blowing starter) first time i did it..didnt even have to take out the front motor mount. even if you have to take out the FMM it aint that difficult. i could do it in 'bout 20 mins if i had to do it again.
-Josiah
Old 06-21-2004, 10:33 PM
Pedros91 Pedros91 is offline
Send a message via AIM to Pedros91
why rotate engine whats with that
Old 07-04-2004, 05:05 PM
doratheneon doratheneon is offline
Re: Re: 97 Starter How To?
I just burned one, the power and the ground have to go on the same screw, closet to the radiator ?
thanks.
