Old 07-12-2004, 03:28 AM   #1
stephenxx21xx
Question how to put a cd player in a 93 lumina
any one know how to put a cd playr in a 93 lumina
stephenxx21xx is offline   Reply With Quote
Old 07-12-2004, 05:41 PM   #2
newfslumina
Re: how to put a cd player in a 93 lumina
the easiest way is to buy an installation kit that will fit the hole of the factory stereo. You can also buy the wire adapter that connects to your factory stereo harness so you dont have to cut any wires...just use heat shrink tubing to cover the joins...and you might also need an adapter for your antenna...you can pick these items up at any automotive audio store for like 30 dollars in all and takes like 30 min to install....hope this helps!!
newfslumina is offline   Reply With Quote
Old 07-22-2004, 03:42 AM   #3
bobng
I have just done it putting a Kenwood CD replacing the cassette. It is not a difficult job at all. And buy the harness and adapter from Walmart, it is a lot cheaper than that audio shop. The only thing you got to be careful is that you should need the deepest face cover because the existing well is very shallow. When it is done the CD may stick out a little bit than the old one. Good luck!
bobng is offline   Reply With Quote
Old 07-23-2004, 02:19 AM   #4
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
If you will be bothered by a standard din sticking out, get a DIN-and-a-half Pioneer for $250-300 (crutchfield). Or maybe just get a mp3/cd changer with fm transmitter.
kevinb70 is offline   Reply With Quote
