Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Talk
Old 06-11-2004, 09:20 PM   #1
brentmcq
best transmission ratios?
What are the best tranny gears for racing assuming 410 rear gears and a motor putting out 400hp. I am thinking tranny #2 because of the closer ratios and the 410's should make up for the loss on the low end. Tranny #1 seems to have a huge gap between 1st and 2nd. Is this line of thinking correct?
Tranny #1 TKO500 (3.27 1.97 1.34 1.00 0.68)
OR
Tranny #2 TKO600 (2.87 1.89 1.28 1.00 0.64)
brentmcq is offline   Reply With Quote
Old 06-12-2004, 11:47 AM   #2
Mendari
Re: best transmission ratios?
Hmm... what kind of racing?
Mendari is offline   Reply With Quote
Old 06-12-2004, 01:42 PM   #3
brentmcq
1/4 mile
Old 06-12-2004, 02:19 PM   #4
boosted331
The TKO500 gear ratios are better suited to a 400 HP car, especially if you're on slicks. How tall of a tire are you going to be running.
boosted331 is offline   Reply With Quote
Old 06-12-2004, 11:31 PM   #5
351wStang
351wStang's Avatar
Whats the max rpm you will be turning this motor?
351wStang is offline   Reply With Quote
Old 06-13-2004, 11:25 PM   #6
brentmcq
I haven't had the gears put in yet and I decided to back off to 373. Max RPM will be at 6000 and I am running stock 16'' rims with gforce TA's. I will be putting on a Procharger 10 PSI as well. Yes traction is an issue that will be dealt with later.
