Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 02-23-2010, 10:54 PM   #1
mybad_z71
putting transfer case in neutral?
hello, i have a 1997 z71 with push button 4x4, it has 2hi 4hi 4lo, no autoshift. does anyone know how to put the transfer case in neutral. i dont have the owners manual and the dealerships here are very un- cooperative, thanks
mybad_z71 is offline   Reply With Quote
Old 02-24-2010, 01:42 AM   #2
RahX
Re: putting transfer case in neutral?
If it has pushbutton and neutral isn't listed then you're out of luck :\
RahX is offline   Reply With Quote
Old 02-24-2010, 09:45 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
Why do you want neutral on it or to put in neutral?
MT
Old 02-24-2010, 09:47 AM   #4
Frankp87
Doesn't putting it in 2Hi automatically put in in neutral?
Frank
1998 Silverado Z71
Frankp87 is offline   Reply With Quote
Old 02-24-2010, 10:15 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
If it did a lot of people would not be leaving home.:sarcasm1:
Neutral is when it is out of gear.
MT
Old 02-24-2010, 10:53 AM   #6
Frankp87
Guess I didn't understand the OP. Putting a transfer case in neutral will prevent you from going anywhere? Thought in 2Hi only the rear wheels were engaged.
Frank
1998 Silverado Z71
Old 02-24-2010, 07:44 PM   #7
777stickman
Well you got a lot of replies but no good answers.
So here it is out of my '98 Owners manual. Your '97 may be different.
Start the engine. If that's not an option then turn the key to the RUN position. Make sure the t-case is in 2HI and the switch light for 2HI is on and steady.
Press and hold both the 2HI and 4LO buttons for at least 10 secs. The NEUTRAL light should come on. Put the tranny lever in REV for one second and then in DRIVE for one second.
Hope this works for you.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 02-24-2010, 08:00 PM   #8
777stickman
The T-Case is the final drive to both the rear and front. So with the t-case in neutral you can put the tranny in any gear you want and you won't "leave home".
57 Chevy 210
Old 02-25-2010, 08:18 PM   #9
mybad_z71
thnks for the replies, especially you stickman, i tried that and it didnt work. the reason i wanted to put it in neutral is because i got a loud whining noise at 40+ mph, i put the rear end on jackstands and removed the rear driveshaft, had my wife get in and run it to 45mph (as my dumbass) got underneath it to try to find out if it was the tranny ot the t-case, i couldnt tell though. so if im able to put the tcase in neutral and the noise goes away i no its coming from the tcase, if not then i know its the tranny, so rite now im kinda stuck guessing which one it is. stickman, does your pushbutton have a neutral light for the tcase? mine doesnt just a light for 2hi, 4 hi/lo, but there would have to be a way to put it in nuetral right? in the event it had to be towed? thanks again guys.
Old 02-25-2010, 10:28 PM   #10
777stickman
Ya my '98 Sub has the Neutral light. It is just to the left of the buttons. I also have the Auto 4WD t-case. I think you have to score an owners manual for your truck to figure it out. Maybe try a junk yard for one or a buddy. Also try a google search.
Good luck.
57 Chevy 210
Old 02-26-2010, 09:55 AM   #11
MT-2500
AF - Advisor
MT-2500's Avatar
You might pull the encoder motor off and see if there is a neutral position on transfer case shift lever.
To tow it place in 2W and lift rear off ground or remove rear drive shat.
Good luck
MT
Old 02-26-2010, 05:35 PM   #12
777stickman
Did some research for my own info and found the a '97 with the NP1 t-case has no provisions for putting it in neutral.
57 Chevy 210
Old 02-26-2010, 07:01 PM   #13
mybad_z71
thx guys, u r great. stickman thx, thats what i was thinking about no neutral, i just couldnt get hold of the info, thx again guys
