Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Register FAQ Social Groups
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-11-2002, 05:24 PM
shaodome shaodome is offline
Send a message via AIM to shaodome
auto and turbo?
Is it even worth it to turbo or supercharge and automatic?
Old 02-12-2002, 02:58 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
It can be but it cant be. You will get more of a turbo lag with an automatic than a 5 or 6 speed because the shifts are different. A supercharger might be more suitable for an automatic than a turbo.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-15-2002, 03:29 PM
gurlie gurlie is offline
Send a message via Yahoo to gurlie
don't turbocharge an automatic, the lag is SO bad, and by the time that it starts to spool up, the car shifts! if you do turbocharge though, you might want to get an ecu from another car with a more aggressive fuel map (gsr, etc..)
Old 02-15-2002, 07:00 PM
TwiLiTe TwiLiTe is offline
Question
Would something like the PTS shiftronic help the lag problem?
Old 02-16-2002, 01:53 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
are you guys talking from experience? obviously not.
autos are the best to turbocharge. unlike a manual, you dont lift your foot off the gas in an auto when it upshifts... by not having to get off the gas pedal, the turbo never spools down. once it spools up, usually by the second gear, it never spins down again.
on a manual, each shift you lift your foot off the throttle, thus closing the tb, blowing off the excess pressure thru the bov, then you shift, get on the gas, and then the turbo begins to spool up again. on an auto, all this is bypassed, and you get constant boost thru all gears until you lift off the throttle.
Old 02-16-2002, 01:55 AM
drift's Avatar
actually, autos have less gears than most manuals... most autos are 4 speeds. due to this, each gear is longer, allowing the turbo to remain spooled up for longer periods of time.
Old 02-16-2002, 01:57 AM
drift's Avatar
it may shift, but it doesnt cause you to lag again since the throttlebody never closes, the turbo continues to spin at nearly full speed.
the lag is "arguable" in first gear... but by second, it's at full boost unless the turbo is entirely too large for the application. and once at full boost in an auto, it doesnt spool down until you lift off the throttle.
Old 02-17-2002, 06:33 PM
SPEEDY SPEEDY is offline
I had the same question but it's pretty much answered now..hey drift..do you think an auto tranny can handle a Turbo running at only 5-6psi? Im gettin a turbo for my car which is auto and im just going to keep it at the stock boost level cause im going to be running on stock internals..
00 Civic coupe..C-G-P
Greddy Turbo Kit
Apexi N1 Exhaust
Black Housed w/ ion Lense headlights
Carbon Fiber Euro Altezzas
Wings West Type W kit
Universal Commando
White 16" Motegi MR7's w/Toyos
Eibach Prokit w/ Tokico Blues
Old 02-17-2002, 07:01 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
the only thing i would say you would have to worry about is if the auto clutches are up to thr task of holding the power produced. and you might wanna look into getting a torque converter with a higher stall speed.
Old 02-19-2002, 05:49 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
Jackson Racing suggested an automatic transmission cooler but did not say it was necessary, when I asked them about my auto holding up with a supercharger.
Old 02-23-2002, 03:26 PM
essinem4130 essinem4130 is offline
Send a message via AIM to essinem4130
Another benefit of an auto turbo setup is you can come off the line with boost. You can hold the brake, hit the gas, and the resistance caused by the torque converter puts the engine under load, spooling the turbo right off the line.
Old 02-23-2002, 10:44 PM
SleeperCivic SleeperCivic is offline
I'm running a turbocharged 5-spd and I must say I DO get my turbo to spool off the line, but I have to hit 4-5k and when I let 'er rip, the front tires just skip off the ground and I feel like the dash is going to fall off. Oh, and that's on the stock tires, haven't tried it on my 18's yet.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 06-15-2004, 02:08 AM
bustedneon bustedneon is offline
Re: auto and turbo?
you guys piss me of arguing all the time, just answer the question that the newbs (like me) ask
Old 06-15-2004, 04:50 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
autos are good cars to turbo. but a trans cooler would be a good idea, it will help prolong the tranny life, or so they say. check out levelten they build auto trannys and can build you a bulletproof auto trans, but it will be expensive.
like the other were saying, you might not see full boost until second gear but after you hit full boost, youll be a full boost for the rest of the race
Team Lonely Drivers
Old 06-15-2004, 09:26 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: auto and turbo?
You could not be so far from the truth Turbos and automatics are like peas and carrots, they go together. Might want a higher stall converter. Besides you don't need to worry about spoolup with an automatic as much. You spool it up once and you are done with it. You don't loose boost everytime you shift. You accually gain boost (If you would not have a wasegate.) It puts the engine under more of a load and flows more exhaust at higher EGT's
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
