Go Back   Automotive Forums .com Car Chat > Oldsmobile > Aurora
Old 04-26-2004, 01:39 PM   #1
Angels_Aurora
Angels_Aurora's Avatar
Bad Engine Possibly
I just recently bought a 1996 Oldsmobile Aurora. The day I got the car, the in dash computer was showing (change oil now). I drove the car constantly for about 4 hours, here and there. Then the computer displayed (low engine coolant). So my friend went in and bought the green prestone coolant. After he added it, we went to get the oil changed. They only added 5 quarts. Within 20 minutes of leaving the shop, the car overheated and I had to turn it off. After letting it cool, I was able to drive it a short distance to my house. Since then I have learned that you are only to add the orange dex-cool coolant. I have flushed the system, replaced the thermostat, changed the water pump. However the car still overheats within 15 minutes of starting it. When it gets hot it blows all of the coolant out the overflow cap. I was told that is sounded like a bad or cracked head gasket. When I called the dealer they told me that Auroras do not have head gaskets go bad, and that I need a brand new engine. Has anyone else had this problem or does anyone have any suggestions. Also I found a product on the web called thermaweld, it is supposed to fix this type of problem for $300.00. Has anyone tried this. Or do you think that it is a bad idea.
Some People Just Don't Know How To Drive...
I Call These People "Everybody But Me."
Angels_Aurora is offline   Reply With Quote
Old 04-26-2004, 11:19 PM   #2
kev's 96 Aurora
kev's 96 Aurora's Avatar
Send a message via AIM to kev's 96 Aurora Send a message via Yahoo to kev's 96 Aurora
I believe cracked heads will either make your car have white cloudy smoke and/or when you take the oil cap off and smell in the fill hole it will have a burnt smell. Also when you drain the oil you might see antifreeze in the oil or it will be really runny(watered down).
Just got a '96 Aurora
89k miles
Mods: Airbox, 20% tint
Very powerful car.
kev's 96 Aurora is offline   Reply With Quote
Old 04-27-2004, 12:02 AM   #3
HARDTIMER
Re: Bad Engine Possibly
also you will see in other threads that you are WAY low on oil. Standard for the auroras is 7.5 quarts. When I had my oil changed the guy actually put in 9 quarts. Doubt if this is causing the overheating, just wanted to let you know.
HARDTIMER is offline   Reply With Quote
Old 04-27-2004, 02:57 PM   #4
Angels_Aurora
Thanks
Thanks for the ideas. I have checked the oil and there is no water or coolant in it. I have added the extra quarts of oil to top it off. Also there is no white smoke coming from the exhaust. However it is burning to rich in the gas department. The exhaust tubes are caked with gasoline residue, and sometimes there is black smoke.
Old 04-27-2004, 03:36 PM   #5
HARDTIMER
dealer diagnostic?
Old 04-28-2004, 10:33 AM   #6
Angels_Aurora
Diagnostic check
I have had a diagnostic check done, and it only shows that the service engine light came on due to the overheating. It also shows that I have low fuel pressure, which I have heard means I need a new fuel pump. It hasn't registered anything else.
Old 04-28-2004, 10:48 PM   #7
97 silverbullet
97 silverbullet's Avatar
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
well if you need to replace your engine I'll take your bad engine.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
97 silverbullet is offline   Reply With Quote
Old 05-19-2004, 11:03 AM   #8
Angels_Aurora
Fixed The Problem - Sort of
After visiting the dealer and being told that there was no other possibility for my overheating problems other than a bad engine. I let my Grandpa tinker with the car. After playing around for a week, he realized that the metal piece that is attached to the insided of the pressurized cap at the coolant tank was missing. He went to the junk yard and for $5.00 he bought a used cap. Guess what it fixed the problem. No more overheating. However last night after driving the car, I noticed the strong smell of fuel. My boyfriend thinks that I have a leak in the fuel rail. So now the car is parked again. Has this happened to anyone else?
Old 05-19-2004, 11:08 AM   #9
RoraStar96
RoraStar96's Avatar
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
there is a recall on the broken fuel lines...get it in for repairs ASAP, dont mess with fuel, its really dangerous O.O
Smell fuel, dont mess around, get it FIXED ASAP!
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
RoraStar96 is offline   Reply With Quote
Old 07-25-2004, 10:04 AM   #10
dougsoval
I just got a '98 with a reported blown head gasket. A post above said "dealer says head gaskets don't go bad..." My car runs well, has some water/white steam/smoke out of the exhausts. I have replacement engine but would love to avoid the work.
dougsoval is offline   Reply With Quote
