Old 05-06-2004, 12:20 PM   #1
MeanWS6
Would bad crank sensor cause random misfire and rough starts?
Ok, readers digest version on my winter beater. It's a 96's Olds 3.1, drove this thing for 80K+ miles without a SINGLE problem. Last month she started throwing P0300 (random misfire) and PO306 (cyl 6 misfire) at idle. So I replaced all the plugs, wires, fuel filter. Threw autotap back on and now cyl 2 was misfiring - so I replaced all six injectors, coil packs, ignition control module, PCM (went overboard but I just wanted this thing fixed)
Still same thing, took it to GM dealership and they said injector 5 was bad, so I replaced it again last night. Now I am getting random misfire codes and occasional misfire on other cylinders at idle and it is taking longer to crank over now.
At a loss rt now, only thing I have not replaced is the crank sensor - could that be the culprit. Or what about the wiring harness?
Guys have any other thoughts?
thanks
1999 WS6 Convertible #3599
Cartek Stage II-X Heads
G5x2 Cam
Maximum Evil Stage III Trans
Yank PYE3600
Moser 12 Bolt / 33 spline / 3.73’s
NXL Direct Port Nitrous (180 shot)
Bunch of other stuff . . . .
Dynoed: 415rwhp NA
No track times yet
2002 Ford Taurus SE (winter beater)
MeanWS6 is offline   Reply With Quote
Old 05-07-2004, 10:20 AM   #2
quaddriver
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
sure it could.
quaddriver is offline   Reply With Quote
