Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-11-2004, 06:06 PM
Easyrider7 Easyrider7 is offline
G-20 will not come out of park when started??
In order to go anywhere I have to turn the key half way, put it in neutral and then start it. I was told there is a fuse or module in the steering column that needs to be replaced. Can someone verify this or give me some possible options???
Thanks.....
Old 02-15-2004, 10:32 AM
Jeremy-WI Jeremy-WI is offline
Re: G-20 will not come out of park when started??
probably the btsi, brake transmission shift interlock
Old 02-15-2004, 03:24 PM
zeeb zeeb is offline
Might be the brake transmission shift interlock thing. One the newer cars you have to have your foot on the brake pedal to shift out of park when running, if it wont do that try checking the interlock out.
Old 03-02-2004, 02:54 AM
DSSDOG's Avatar
DSSDOG DSSDOG is offline
Send a message via Yahoo to DSSDOG
Eh Sounds stupid but check the Rear Brake light Bulb... I had a 97 Ford Exploder that had same problem replaced a Brake light Driver side rear and BOOM fixed problem... also check the Brake light switch located on the upper portion of the brake pedal... good luck
w00F...
