Register FAQ Social Groups
Old 12-28-2003, 08:20 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Question On Fuel Pump?
My question is I am leaking some gas out of, well, I think its the fuel pump, but I dunno. Its the little module that sits towards the top passenger side of the firewall. It has a banjo bolt on it. I looked in the almighty "hanes" manual and it said that should be torqued at 16 ft-lbs. Well i had it torqued even more that that and it was still leaking. I didnt see any brass washers or and gaskets when I took this off when I did the engine swap. Do I need to get some? If so, are they brass or are they gaskets?
Old 12-28-2003, 08:32 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Question On Fuel Pump?
That is the fuel filter. Might as well buy a new fuel filter as it comes with new brass crush washers, that should solve the problem.
Old 12-28-2003, 10:18 PM
BullShifter's Avatar
BullShifter BullShifter is offline
There should be 2 washer on each connection @ the f/filter
http://www.binghamtonlife.com/manual.../91-11-108.jpg
Throw your manual away & get a real one - www.helminc.com
Old 12-29-2003, 10:29 AM
Yea, I am gonna. It was joke. But I know, Hanes SUCKS ASS. They barely give you any info. For an example, I had to disconnect the shifter linkage and it says, "Remove the pin." Thats it. What a waste of money.
Old 12-29-2003, 10:50 AM
crx91's Avatar
crx91 crx91 is offline
buy the dealer book its a little more but it tells you everything
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 11:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 03:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
